Colibri T30 operating environment
In relation to the colibri T30 module, is there any information in relation to:
Ambient operating temperature range from … to … (this is TBC on the datasheet).
Operating relative humidity range
Operating atmospheric pressure range
Storage and transportation ambient temperature range
Storage and transportation relative humidity range
Storage and transportation atmospheric pressure range
Note that I realise that the Ambient operating temperature range partly depends on the loading, but is there a basic figure?
We don’t have any information related to humidity and atmospheric pressure operation range. Storage temperature we are currently investigating and will update the datasheet accordingly.
Unfortunately we neither have any graphs on operating temperature and work load.
CPU Details
CPU Name
CPU Type
CPU Clock
Floating Point Unit
NEON
L1 Instruction Cache
L1 Data Cache
L2 Cache
Memory
RAM
Flash
Connectivity
USB
Ethernet
External Bus
I2C
SPI
One-Wire
UART
IrDA
PWM
Analog Input
SDIO/SD/MMC
Multimedia
Individual Displays
Graphics Controller
Video Decoder
Video Encoder
S/PDIF In / Out
2D Acceleration
3D Acceleration
HDMI
VGA
RGB
Resistive Touch
Camera Parallel Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
Operating System
Windows Embedded Compact 7
Windows Embedded Compact 2013
Embedded Linux
Android
Preinstalled OS
Physical
Size
Temperature
Power Dissipation
Minimum Availability(1)
Pricing
Colibri T30 1GB Colibri T30 1GB
Industrial Temperature (IT)
NVIDIA® Tegra™ 3 NVIDIA® Tegra™ 3
ARM Cortex™-A9 ARM Cortex™-A9
Up to 1.4 GHz Up to 1.4 GHz
VFPv3 VFPv3
Yes Yes
32KB per core 32KB per core
1MByte 1MByte
1GB DDR3L (32 Bit) 1GB DDR3L (32 Bit)
4GB eMMC (8 Bit) 4GB eMMC (8 Bit)
1x Host (High Speed)
1x OTG (High Speed) 1x Host (High Speed)
1x OTG (High Speed)
10/100 Mbit 10/100 Mbit
16 Bit 16 Bit
3x + DDC 3x + DDC
6x 6x
1x 1x
5x 5x
1x 1x
4x 4x
4x (12 Bit) 4x (12 Bit)
3x 4 Bit 3x 4 Bit
2x 2x
Integrated Ultra-low power NVIDIA GeForce GPU Integrated Ultra-low power NVIDIA GeForce GPU
DiVX 4/5/6, H.263, H.264, JPEG, MPEG-2, MPEG-4, WMV9 VC-1, XviD DiVX 4/5/6, H.263, H.264, JPEG, MPEG-2, MPEG-4, WMV9 VC-1, XviD
H.263, H.264, JPEG, MPEG-4 H.263, H.264, JPEG, MPEG-4
1x 1x
Yes Yes
Yes Yes
V1.4a 1080p (1920x1080) V1.4a 1080p (1920x1080)
1920x1200 1920x1200
2048x1536x24bpp 2048x1536x24bpp
4-wire 4-wire
1x 1x
1x (Stereo) 1x (Stereo)
1x (Mono) 1x (Mono)
Supported Supported
Supported Supported
Supported Supported
Supported by third party Supported by third party
Windows Embedded Compact 7 Windows Embedded Compact 7
67.6 x 36.7 x 6.2 mm 67.6 x 36.7 x 6.2 mm
0° to 70° C -40° to +85° C
1.4 - 5.1 W 1.4 - 5.1 W
2025 2025
