I have an issue with HDMI without audio output, I have seen the Colibri T30 supports HDMI audio output.
But I have tried the kernel of the 2013 version to comment out “#define TEGRA_FB_VGA”, which is not working, so how to enable HDMI audio??
Your prompt reply would be greatly appreciated.
Okay, I have taken some time to satisfy my purpose.
However, those documents are very messed up, and have no complete route map to check something. I combined this with Google search to support my work…
To be honest, I have finished my work. But I have worked on embedded Linux for about ten years, I have not seen messed up documents, jump to somewhere or jump back… It takes much time to retrieve useful information, even worse than sunxi (China Allwinner).
[ 3.189459] tegradc tegradc.0: probed
[ 3.193255] tegradc tegradc.0: use cmd options for tegrafb0: 1920x1080-16@60
[ 3.200326] tegradc tegradc.0: switching framebuffer to 1920x1080
[ 3.206421] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 3.212094] tegradc tegradc.0: using mode 1920x1080 pclk=148500000 href=0 vref=1
[ 3.224284] tegradc tegradc.0: switching framebuffer to 1920x1080
[ 3.224293] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 3.224303] tegradc tegradc.0: using mode 1920x1080 pclk=148500000 href=0 vref=1
[ 3.255942] Console: switching to colour frame buffer device 240x67
[ 3.297751] tegradc tegradc.0: probed
[ 3.311674] tegradc tegradc.1: probed
[ 3.315570] tegradc tegradc.1: use cmd options for tegrafb1: 1920x1080-16@60
[ 3.322707] tegradc tegradc.1: switching framebuffer to 1920x1080
[ 3.328859] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[ 3.341886] tegradc tegradc.1: probed
[ 3.602132] tegradc tegradc.1: display detected
[ 12.486562] ALSA device list:
[ 12.498149] #0: colibri_t30-sgtl5000
[ 12.510011] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
NV5.txt (44.4 KB)
