Hi, what is the maximum length allowed for the HDMI cable on Colibri T20? I could not find any references on the toradex wiki.
Colibri T20 512MB v1.2A
Colibri HDMI Adapter
According to the HDMI standard the maximum length is 30 meter. I have succeded in using a 10 meter HDMI cable with a T30 on custom hardware.
But if this also apply to the T20 i dont know
Hi @f.ruscelli!
In the industry, it is usual to not exceed 5 meters with passive cables.
There are cases where 8 meters still works, but anything longer can cause communication issues.
Also, if you need to reach greater distances, you can use an active HDMI cable.
