I have a corrupted PXA320, that I attempted to restore using the Colibri loader, but it seems I overwrote the config block somehow*. Now when I use the Colibri loader it gives an error stating “Unknown Flash Type”.
Is there a procedure using JTAG (openocd) or some other means of rewriting the memory? I can’t find a working Openocd config to read/write the NAND on the PXA320.
Hw is revision 1.2.
*I attempted to copy the Uboot loader off another PXA320 copied using DD from /dev/mtb0 then used CreateTBin and attempted to write it back but it created a length that was +47 bytes larger than the actual image for some reason.
