When I use Tezi 2.0b6 in recovery mode on Iris 1.1B I got this:
In UART from Iris board:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g9393e0c9bd (May 19 2020 - 21:36:48 +0000)
CPU: Freescale i.MX8QXP revB A35 at 1200 MHz at 29C
DRAM: 2 GiB
PMIC: device id: 0x40, revision id: 0x20, emrev 0, prog id fff
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT V1.0B, Serial# 06494192
BuildInfo:
- SCFW b929edfe, SECO-FW f449a0d2, IMX-MKIMAGE d7f9440d, ATF bb209a0
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g9393e0c9bd
Detect USB boot. Will enter fastboot mode!
flash target is MMC:0
Net: eth0: ethernet@5b040000 [PRIME]
Fastboot: Normal
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: fastboot 0
Starting download of 2246 bytes
downloading of 2246 bytes finished
Starting download of 37580496 bytes
downloading of 37580496 bytes finished
## Executing script at 82e00000
## Loading kernel from FIT Image at 83000000 ...
Using 'config@freescale_fsl-imx8qxp-colibri-eval-v3.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x8300010c
Data Size: 6689273 Bytes = 6.4 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80280000
Entry Point: 0x80280000
Hash algo: sha1
Hash value: 166f527127b4e212cc5a5d63376ae48c22628051
Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 83000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x836c8534
Data Size: 30466048 Bytes = 29.1 MiB
OS: Linux
Load Address: 0xa0000000
Entry Point: unavailable
Hash algo: sha1
Hash value: 7170742b7e38e68cc7331eb019e5de4c28ce538d
Loading ramdisk from 0x836c8534 to 0xa0000000
## Loading fdt from FIT Image at 83000000 ...
Trying 'fdt@freescale_fsl-imx8qxp-colibri-eval-v3.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x83661428
Data Size: 84042 Bytes = 82.1 KiB
Hash algo: sha1
Hash value: 5075a816962b48701bdee4ded29c65b247579a06
Booting using the fdt blob at 0x83661428
Uncompressing Kernel Image ... OK
Loading Device Tree to 00000000fd663000, end 00000000fd67a849 ... OK
/dma-controller@591F0000, 64852
/dma-controller@599F0000, 65816
/dma-controller@5a1f0000, 63900
Starting kernel ...
[ 0.350188] dmi: Firmware registration failed.
[ 0.773192] Can't support > 32 bit dma.
Running /etc/rc.local...
TDX_VER_ID="Colibri-iMX8X_ToradexEasyInstaller_2.0b6-20201102"
Starting udev
System time was Wed Nov 18 13:55:35 UTC 2020.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Wed Nov 18 13:55:35 UTC 2020.
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
# ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
I can’t connect to VNC server but I figured out how to install Tezi (or other image) from CLI.
/usr/bin/tezictl image-list
Currently available images:
[0] TorizonCore with evaluation containers for V1.0C HW
Version: 5.1.0-devel-202011+build.4.container (2020-11-06)
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/monthly/4/colibri-imx8x/torizon/torizon-core-docker-evaluation/teziimage/
[1] TorizonCore with evaluation containers for V1.0B HW
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/monthly/4/colibri-imx8x-v10b/torizon/torizon-core-docker-evaluation/teziimage/
[2] TorizonCore for V1.0B HW
Version: 5.1.0-devel-202011+build.4 (2020-11-06)
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/monthly/4/colibri-imx8x-v10b/torizon/torizon-core-docker/teziimage/
[3] TorizonCore for V1.0C HW
URI: http://tezi.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/monthly/4/colibri-imx8x/torizon/torizon-core-docker/teziimage/
[4] Toradex Easy Installer
Version: 2.0b6 (20201102)
URI: http://tezi.toradex.com/artifactory/tezi-oe-prod-frankfurt/thud/release/2/colibri-imx8x/tezi/tezi-run/teziimage/
[5] Toradex Embedded Linux Reference Minimal Image for V1.0B HW
Version: 5.0.0+build.3 (2020-10-06)
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/3/colibri-imx8x-v10b/tdx-xwayland/tdx-reference-minimal-image/teziimage/Colibri-iMX8X-V10B_Reference-Minimal-Image-Tezi_5.0.0+build.3/
[6] Toradex Embedded Linux Reference Multimedia Image for V1.0B HW
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/3/colibri-imx8x-v10b/tdx-xwayland/tdx-reference-multimedia-image/teziimage/Colibri-iMX8X-V10B_Reference-Multimedia-Image-Tezi_5.0.0+build.3/
[7] Toradex Embedded Linux Reference Minimal Image
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/3/colibri-imx8x/tdx-xwayland/tdx-reference-minimal-image/teziimage/Colibri-iMX8X_Reference-Minimal-Image-Tezi_5.0.0+build.3/
[8] Toradex Embedded Linux Reference Multimedia Image
URI: http://tezi.toradex.com/artifactory/tdxref-oe-prod-frankfurt/dunfell-5.x.y/release/3/colibri-imx8x/tdx-xwayland/tdx-reference-multimedia-image/teziimage/Colibri-iMX8X_Reference-Multimedia-Image-Tezi_5.0.0+build.3/
[9] Qt for Device Creation Demo Image
Version: Qt 5.15.1 (2020-09-07)
URI: http://tezi.toradex.com/artifactory/legacy-oe-3rdpartyprod-frankfurt/b2qt-embedded-qt5-image-colibri-imx8x-20200907064801-Tezi_3.0.3/
[10] Kynetics Android Pie for Colibri iMX8QXP V1.0B
Version: 1.0-SNAPSHOT-20190823 (20190829)
URI: http://tezi.toradex.com/artifactory/legacy-oe-3rdpartyprod-frankfurt/Colibri-iMX8QXP_V1.0B_Kynetics-Android-Image_9.0.0_2.0.1-eval-1.0-SNAPSHOT-20190823/
/ # /usr/bin/tezictl image-install 4
Image installation started, please wait...
Success: Image installation finished!
/ # reboot -f
[ 687.873244] reboot: Restarting system
CPU: Freescale i.MX8QXP revB A35 at 1200 MHz at 56C
DRAM: 2 GiB
Loading Environment from MMC… *** Warning - bad CRC, using default environment
Failed (-5)
In: serial
Out: serial
Err: serial
BuildInfo:
Fastboot: Normal
[Hangs]
Then I turn off/on power and nothing appears on UART.
To answer Your questiions, yes, I am able to isntall TorizonCore 5.1.0 from CLI (tezi v 2.0b6 as just desribed) or even via VNC with newer versions from night builds.
I do not need to install Tezi or Use TorizonCore (at least at the moment), just bumped on this behavior and wanted to make some feedback.
