Hi Technical support team,
We are using below Toradex board and customized kernel image.
Colibri iMX8QXP 2GB WB IT.
iris carrier 1.1A.
Linux BSP 5.4
This below link is used for kernel compliation.
https://developer.toradex.com/knowledge-base/build-u-boot-and-linux-kernel-from-source-code
Issue facing is specific Wi-Fi driver not found for on module Wi-Fi(AW-CM276NF).Please help me regarding this problem which driver need to be enabled.
regarding and Thanks
Ajay
