Compare DT “eval-v3” vs iris-v2
very little difference
HTML with colors: compare.html (47.0 KB generator:WinMerge)
*** tmp_eval-v3.txt Tue Oct 12 14:22:26 2021
--- tmp_iris-v2.txt Tue Oct 12 14:22:38 2021
*** 1,20 ****
! # 1 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-eval-v3.dts"
# 1 "<built-in>"
# 1 "<command-line>"
/dts-v1/;
# 1 "arch/arm64/boot/dts/freescale/imx8qxp-colibri.dtsi" 1
# 1 "./scripts/dtc/include-prefixes/dt-bindings/pwm/pwm.h" 1
# 7 "arch/arm64/boot/dts/freescale/imx8qxp-colibri.dtsi" 2
# 1 "arch/arm64/boot/dts/freescale/imx8qxp.dtsi" 1
--- 1,20 ----
! # 1 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-iris-v2.dts"
# 1 "<built-in>"
/dts-v1/;
*** 6217,6266 ****
compatible = "fsl,imx8-mu1-vpu-m0";
reg = <0x1020000 0x20000>;
reg-csr = <0x1050000 0x10000>;
interrupts = <0 470 4>;
fsl,vpu_ap_mu_id = <17>;
fw-buf-size = <0x200000>;
rpc-buf-size = <0x80000>;
print-buf-size = <0x80000>;
# 9 "arch/arm64/boot/dts/freescale/imx8qxp-colibri.dtsi" 2
model = "Toradex Colibri iMX8QXP Module";
compatible = "toradex,colibri-imx8x", "fsl,imx8qxp";
! # 9 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-eval-v3.dts" 2
! # 1 "arch/arm64/boot/dts/freescale/imx8x-colibri-eval-v3.dtsi" 1
aliases {
rtc0 = &rtc_i2c;
- rtc1 = &rtc;
- clk16m: clock-16mhz-fixed {
- compatible = "fixed-clock";
- #clock-cells = <0>;
- clock-frequency = <16000000>;
extcon_usbc_det: usbc_det {
compatible = "linux,extcon-usb-gpio";
debounce = <25>;
id-gpio = <&lsio_gpio5 9 0>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_usbc_det>;
reg_3v3: regulator-3v3 {
compatible = "regulator-fixed";
regulator-name = "3.3V";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
--- 6217,6264 ----
! # 9 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-iris-v2.dts" 2
! # 1 "arch/arm64/boot/dts/freescale/imx8x-colibri-iris-v2.dtsi" 1
! # 1 "arch/arm64/boot/dts/freescale/imx8x-colibri-iris.dtsi" 1
aliases {
rtc0 = &rtc_i2c;
debounce = <25>;
*** 6291,6409 ****
&fec1 {
&i2c1 {
rtc_i2c: rtc@68 {
compatible = "st,m41t0";
reg = <0x68>;
tca8418@34 {
compatible = "ti,tca8418";
reg = <0x34>;
interrupt-parent = <&lsio_gpio3>;
interrupts = <21 3>;
keypad,num-rows = <5>;
keypad,num-columns = <7>;
linux,keymap = <
! # 110 "arch/arm64/boot/dts/freescale/imx8x-colibri-eval-v3.dtsi"
((((0x03) & 0xFF) << 24) | (((0x02) & 0xFF) << 16) | ((11) & 0xFFFF))
((((0x03) & 0xFF) << 24) | (((0x03) & 0xFF) << 16) | ((10) & 0xFFFF))
((((0x03) & 0xFF) << 24) | (((0x04) & 0xFF) << 16) | ((9) & 0xFFFF))
((((0x03) & 0xFF) << 24) | (((0x05) & 0xFF) << 16) | ((8) & 0xFFFF))
((((0x03) & 0xFF) << 24) | (((0x06) & 0xFF) << 16) | ((7) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x01) & 0xFF) << 16) | ((14) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x02) & 0xFF) << 16) | ((6) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x03) & 0xFF) << 16) | ((5) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x04) & 0xFF) << 16) | ((4) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x05) & 0xFF) << 16) | ((3) & 0xFFFF))
((((0x04) & 0xFF) << 24) | (((0x06) & 0xFF) << 16) | ((2) & 0xFFFF))
- &jpegdec {
- status = "okay";
! &jpegenc {
! status = "okay";
! &lpspi2 {
! mcp2515: can@0 {
! compatible = "microchip,mcp2515";
! pinctrl-names = "default";
! pinctrl-0 = <&pinctrl_can_int>;
! reg = <0>;
! clocks = <&clk16m>;
! interrupt-parent = <&lsio_gpio3>;
! interrupts = <13 2>;
! spi-max-frequency = <10000000>;
! spidev0: spidev@0 {
! status = "disabled";
&lpuart0 {
&lpuart2 {
&lpuart3 {
status= "okay";
&lsio_gpio3 {
pad-wakeup = <157 6 10>;
pad-wakeup-num = <1>;
&pwm0 {
&pwm1 {
&pwm2 {
&usb3phynop1 {
--- 6289,6427 ----
&fec1 {
&i2c1 {
rtc_i2c: rtc@68 {
reg = <0x68>;
tca8418@34 {
reg = <0x34>;
linux,keymap = <
! # 101 "arch/arm64/boot/dts/freescale/imx8x-colibri-iris.dtsi"
+ &iomuxc { pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_gpio_iris>;
+ gpio {
+ pinctrl_gpio_iris: gpio-iris {
+ fsl,pins = <
+ 169 4 0x20
+ 5 4 0x20
+ 82 4 0x20
+ 85 4 0x20
+ 84 4 0x20
+ 44 4 0x06000020
+ 83 4 0x20
+ 157 4 0x06700041
! uart {
! pinctrl_uart1_forceoff: uart1_forceoff {
! fsl,pins = <
! 161 4 0x20
+ pinctrl_uart23_forceoff: uart23_forceoff {
+ fsl,pins = <
+ 123 4 0x20
! &jpegdec {
! &jpegenc {
! status = "okay";
&lpuart0 {
&lpuart2 {
&lpuart3 {
status= "okay";
&lsio_gpio3 {
+ lvds_tx_on {
+ gpio-hog;
+ gpios = <18 0>;
+ output-high;
&pwm0 {
&pwm1 {
&pwm2 {
&usb3phynop1 {
*** 6434,6457 ****
&usdhc2 {
&vpu_decoder {
&vpu_encoder {
&vpu_lpcg {
! # 10 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-eval-v3.dts" 2
! model = "Toradex Colibri iMX8QXP on Colibri Evaluation Board V3";
! compatible = "toradex,colibri-imx8x-eval-v3",
"fsl,imx8qxp";
--- 6452,6516 ----
&usdhc2 {
&vpu_decoder {
&vpu_encoder {
&vpu_lpcg {
! # 7 "arch/arm64/boot/dts/freescale/imx8x-colibri-iris-v2.dtsi" 2
! reg_3v3_vmmc: regulator-3v3-vmmc {
! compatible = "regulator-fixed";
! pinctrl-0 = <&pinctrl_enable_3v3_vmmc>;
! regulator-name = "3v3_vmmc";
! regulator-min-microvolt = <3300000>;
! regulator-max-microvolt = <3300000>;
! gpio = <&lsio_gpio0 31 0>;
! startup-delay-us = <100>;
! enable-active-high;
! &iomuxc {
! pinctrl-0 = <&pinctrl_lvds_converter &pinctrl_gpio_iris>;
! usdhc {
! pinctrl_enable_3v3_vmmc: enable_3v3_vmmc {
! fsl,pins = <
! 88 4 0x20
! &usdhc2 {
! pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep";
! sd-uhs-sdr12;
! sd-uhs-sdr25;
! sd-uhs-sdr50;
! sd-uhs-sdr104;
! cap-power-off-card;
! /delete-property/ keep-power-in-suspend;
! vmmc-supply = <®_3v3_vmmc>;
! status = "okay";
! # 10 "arch/arm64/boot/dts/freescale/imx8qxp-colibri-iris-v2.dts" 2
! model = "Toradex Colibri iMX8QXP on Colibri Iris V2 Board";
! compatible = "toradex,colibri-imx8x-iris-v2",
"fsl,imx8qxp";
