Is possible set " High-throughput Access Point" on Colibri imx8x ?
After add ht_capab and start hostapd /etc/hostapd.conf I have:
Driver does not support configured HT capability [RX-STBC*]
uap0: interface state COUNTRY_UPDATE->DISABLED
uap0: AP-DISABLED
uap0: interface state DISABLED->DISABLED
uap0: AP-DISABLED
uap0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface uap0 wasn’t started
I thought that the drivers for the built-in Wifi card were already in the system image.
Maybe I didn’t read something.
I will investigate this thread
And could you please elaborate on why you would need to enable the “High-throughput Access Point”?
I want to send the image to many devices in real time (or almost) via WiFi
I wanted to check this option to see if it would be better for my performance problems
What features did you specify in ht_capab= line and what capabilities does iw phy report? hostapd will fail to start if specified feature isn’t available from driver. Perhaps try this nice Gateworks script to craft your hostpad.conf. Bit outdated but still useful: hostapd-conf
The images have already the open source drivers for the Wi-Fi/Bluetooth module. I just asked if you are having issues with the open-source drivers or with the proprietary ones from NXP.
Thanks for sharing your context. Could you please be more specific about your requirements? Also, what are exactly those performance problems you are facing? The more specific is the information you can share, better we can understand your use case
Also, please share a simple way of reproducing the problems you are having.
