TEZI Version: Colibri-iMX8X_ToradexEasyInstaller_6.6.0+build.6
> ./recovery-linux.sh
Downloading Toradex Easy Installer...
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.127-0-g08c58c9
Success 1 Failure 0
1:6 8/ 8 [Done ] FB: done
Successfully downloaded Toradex Easy Installer.
However, the boot looks like it loops:
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 43C
DRAM: 2 GiB
Core: 240 devices, 20 uclasses, devicetree: separate
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from nowhere... OK
In: serial
Out: serial
Err: serial
Model: Toradex 0038 Colibri iMX8QXP 2GB WB IT V1.0D
Serial#: 07329824
BuildInfo:
- SCFW 6638c032, SECO-FW c9de51c0, IMX-MKIMAGE 3bfcfccb, ATF 3c1583b
- U-Boot 2022.04-6.6.0+git.d262075124dc
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for uuu
Starting download of 1767 bytes
downloading of 1767 bytes finished
Starting download of 52 bytes
downloading of 52 bytes finished
Starting download of 44598236 bytes
downloading of 44598236 bytes finished
## Executing script at 82e00000
Bootargs: quiet video=DPI-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall clk_ignore_unused pci=nomsi
## Loading kernel from FIT Image at 8a000000 ...
Using 'conf-freescale_imx8qxp-colibri-eval-v3.dtb' configuration
Trying 'kernel-1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x8a000108
Data Size: 9932599 Bytes = 9.5 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x96000000
Entry Point: 0x96000000
Hash algo: sha256
Hash value: 19451322bd116fad9be9a6f6e3a91e5e9c7824fc9f5148c8dff24e8d88aef573
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 8a000000 ...
Trying 'ramdisk-1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x8aa6d398
Data Size: 33660928 Bytes = 32.1 MiB
OS: Linux
Load Address: 0xa0000000
Entry Point: unavailable
Hash algo: sha256
Hash value: 1680260b98bd18c5a9a09c06601a9efb39b4c8a842318ecfe77557cb533fc000
Loading ramdisk from 0x8aa6d398 to 0xa0000000
## Loading fdt from FIT Image at 8a000000 ...
Trying 'fdt-freescale_imx8qxp-colibri-eval-v3.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x8aa0e0b8
Data Size: 122166 Bytes = 119.3 KiB
Load Address: 0x87000000
Hash algo: sha256
Hash value: 6f9a6d5c68e55af17093d7fb3de576fc8a6989153613a1366276ae9a1d0ec9ba
Loading fdt from 0x8aa0e0b8 to 0x87000000
Using 'conf-colibri-imx8x_vga-640x480_overlay.dtbo' configuration
Trying 'fdt-colibri-imx8x_vga-640x480_overlay.dtbo' fdt subimage
Data Start: 0x8aa6cab0
Data Size: 2062 Bytes = 2 KiB
Load Address: 0x870f0000
Hash algo: sha256
Hash value: cc423bd1ab37d8545829df04c6d48398f4d1f00af479029905406a6b6d6ecabe
Booting using the fdt blob at 0x87000000
Uncompressing Kernel Image
Loading Device Tree to 00000000fd651000, end 00000000fd672014 ... OK
Starting kernel ...
[ 0.664882] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 1.077628] debugfs: Directory 'lvds1' with parent 'pm_genpd' already present!
[ 1.085830] debugfs: Directory 'mipi1-i2c1' with parent 'pm_genpd' already present!
[ 1.093579] debugfs: Directory 'mipi1-i2c0' with parent 'pm_genpd' already present!
[ 1.101329] debugfs: Directory 'mipi1-pwm0' with parent 'pm_genpd' already present!
[ 1.109076] debugfs: Directory 'mipi1' with parent 'pm_genpd' already present!
[ 10.974316] mmc1: Timeout waiting for hardware interrupt.
[ 10.979801] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 10.986316] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00000002
[ 10.992829] mmc1: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000008
[ 10.999345] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x0000003b
[ 11.005860] mmc1: sdhci: Present: 0x01fd820e | Host ctl: 0x00000012
[ 11.012376] mmc1: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 11.018892] mmc1: sdhci: Wake-up: 0x00000008 | Clock: 0x0000003f
[ 11.025407] mmc1: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 11.031922] mmc1: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 11.038438] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 11.044954] mmc1: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 11.051469] mmc1: sdhci: Cmd: 0x0000123a | Max curr: 0x00ffffff
[ 11.057985] mmc1: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x00e6877f
[ 11.064501] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 11.071016] mmc1: sdhci: Host ctl2: 0x00000000
[ 11.075507] mmc1: sdhci: ADMA Err: 0x00000003 | ADMA Ptr: 0x99219204
[ 11.082023] mmc1: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 11.090963] mmc1: sdhci-esdhc-imx: cmd debug status: 0x3100
[ 11.097963] mmc1: sdhci-esdhc-imx: data debug status: 0x32a0
[ 11.104682] mmc1: sdhci-esdhc-imx: trans debug status: 0x33a0
[ 11.111460] mmc1: sdhci-esdhc-imx: dma debug status: 0x3400
[ 11.118043] mmc1: sdhci-esdhc-imx: adma debug status: 0x35b4
[ 11.124679] mmc1: sdhci-esdhc-imx: fifo debug status: 0x3680
[ 11.131280] mmc1: sdhci-esdhc-imx: async fifo debug status: 0x3750
[ 11.138383] mmc1: sdhci: ============================================
[ 21.214312] mmc1: Timeout waiting for hardware interrupt.
[ 21.220804] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 21.228304] mmc1: sdhci: Sys addr: 0x00000008 | Version: 0x00000002
[ 21.235799] mmc1: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000008
[ 21.243279] mmc1: sdhci: Argument: 0x00000000 | Trn mode: 0x0000003b
[ 21.250746] mmc1: sdhci: Present: 0x01fd820e | Host ctl: 0x00000012
[ 21.258213] mmc1: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 21.265687] mmc1: sdhci: Wake-up: 0x00000008 | Clock: 0x0000003f
[ 21.273152] mmc1: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 21.280611] mmc1: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 21.288085] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000502
[ 21.295564] mmc1: sdhci: Caps: 0x07eb0000 | Caps_1: 0x0000b407
[ 21.303038] mmc1: sdhci: Cmd: 0x0000123a | Max curr: 0x00ffffff
[ 21.310505] mmc1: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x00e6877f
[ 21.317976] mmc1: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 21.325437] mmc1: sdhci: Host ctl2: 0x00000000
[ 21.330884] mmc1: sdhci: ADMA Err: 0x00000003 | ADMA Ptr: 0x99219204
[ 21.338370] mmc1: sdhci-esdhc-imx: ========= ESDHC IMX DEBUG STATUS DUMP =========
[ 21.348003] mmc1: sdhci-esdhc-imx: cmd debug status: 0x3100
[ 21.354735] mmc1: sdhci-esdhc-imx: data debug status: 0x32a0
[ 21.361518] mmc1: sdhci-esdhc-imx: trans debug status: 0x33a2
[ 21.368369] mmc1: sdhci-esdhc-imx: dma debug status: 0x3400
[ 21.375043] mmc1: sdhci-esdhc-imx: adma debug status: 0x35b4
[ 21.381810] mmc1: sdhci-esdhc-imx: fifo debug status: 0x3680
[ 21.388564] mmc1: sdhci-esdhc-imx: async fifo debug status: 0x3750
[ 21.395844] mmc1: sdhci: ============================================
[ 31.710312] mmc1: Timeout waiting for hardware interrupt.
[ 31.716765] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
