Stuck with below text and could not able to resolve.
Please find the below error attached text and request your support!
U-Boot 2020.04-5.5.0-devel+git.81bc8894031d (Nov 30 2021 - 11:36:12 +0000)
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 44C
DRAM: 1022 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX8 DualX 1GB V1.0D, Serial# 14714799
BuildInfo:
- SCFW 778670e2, SECO-FW 7aeb8423, IMX-MKIMAGE 8947fea3, ATF 835a8f6
- U-Boot 2020.04-5.5.0-devel+git.81bc8894031d
flash target is MMC:0
Net: eth0: ethernet@5b040000 [PRIME]
Fastboot: Normal
Normal Boot
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1…
Scanning mmc 0:1…
Found U-Boot script /boot.scr
5752 bytes read in 27 ms (208 KiB/s)
Executing script at 83200000
Loading DeviceTree: imx8dx-colibri-eval-v3.dtb
126687 bytes read in 17 ms (7.1 MiB/s)
620 bytes read in 19 ms (31.3 KiB/s)
Applying Overlay: colibri-imx8x_parallel-rgb_overlay.dtbo
1498 bytes read in 20 ms (72.3 KiB/s)
Applying Overlay: colibri-imx8x_atmel-mxt-connector_overlay.dtbo
523 bytes read in 17 ms (29.3 KiB/s)
Applying Overlay: display-lt161010_overlay.dtbo
863 bytes read in 13 ms (64.5 KiB/s)
10446704 bytes read in 343 ms (29 MiB/s)
Uncompressed size: 25086464 = 0x17ECA00
Bootargs: root=PARTUUID=19aa7b3f-02 ro rootwait video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off console=null quiet
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
Loading Device Tree to 00000000bd629000, end 00000000bd66afff … OK
Starting kernel …
[ 0.121971] No BMan portals available!
[ 0.123414] No QMan portals available!
[ 0.256299] imx8qxp-lpcg-clk 37620000.clock-controller: failed to get clock parent names
[ 0.433658] mxsfb 5a180000.lcdif: Failed to create outputs
[ 0.815382] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 0.943503] debugfs: Directory ‘59040000.sai’ with parent ‘imx8qxp-sgtl5000’ already present!
[ 1.170503] imx6q-pcie 5f010000.pcie: ERROR PM_REQ_CORE_RST is still set.
[ 1.198387] imx6q-pcie 5f010000.pcie: PCIe PLL lock timeout
[ 3.749212] atmel_mxt_ts 17-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 3.773533] atmel_mxt_ts 17-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 3.791644] atmel_mxt_ts 17-004a: mxt_bootloader_read: i2c recv failed (-5)
[ OK ] Stopped Hardware RNG Entropy Gatherer Daemon.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
[ OK ] Started Reboot.
[ OK ] Reached target Reboot.
[ 13.516169] reboot: Restarting system
Also, for reference, attaching the working text content!
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 36C
DRAM: 1022 MiB
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX8 DualX 1GB V1.0D, Serial# 14755421
BuildInfo:
Fastboot: Normal
Normal Boot
Scanning mmc 1:1…
Scanning mmc 0:1…
5752 bytes read in 26 ms (215.8 KiB/s)
126687 bytes read in 18 ms (6.7 MiB/s)
10446704 bytes read in 344 ms (29 MiB/s)
Bootargs: root=PARTUUID=9d049b21-02 ro rootwait video=imxdpufb5:off video=imxdpu fb6:off video=imxdpufb7:off console=null quiet
Starting kernel …
[ 0.121637] No BMan portals available!
[ 0.122818] No QMan portals available!
[ 0.256592] imx8qxp-lpcg-clk 37620000.clock-controller: failed to get clock p arent names
[ 0.434133] mxsfb 5a180000.lcdif: Failed to create outputs
[ 0.814767] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invali d
[ 0.930660] debugfs: Directory ‘59040000.sai’ with parent ‘imx8qxp-sgtl5000’ already present!
[ 1.157778] imx6q-pcie 5f010000.pcie: ERROR PM_REQ_CORE_RST is still set.
[ 1.185648] imx6q-pcie 5f010000.pcie: PCIe PLL lock timeout
[ 3.696595] atmel_mxt_ts 17-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 3.713318] atmel_mxt_ts 17-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 3.752441] atmel_mxt_ts 17-004a: mxt_bootloader_read: i2c recv failed (-5)
[FAILED] Failed to start Start a wayland application.
See ‘systemctl status wayland-app-launch.service’ for details.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
