Hi Toradex team,
We are using Colibri imx7d som in our Switch devices. We are using form long time and these units are running successfully in the field. but recently we have incurred some problem in the Colibri imx7d som is continuously rebooting. After analyzing we have found that the config block and partition in som are corrupted.
we are unable re-load new OS in those SOM's with our board and with Colibri evaluation board also. Please suggest us what we do we have 30 units in that situation.
when we power ON the board we are continuously getting below messges
U-Boot 2020.07-5.4.0-devel+git.eb6c58cb0140 (Aug 20 2021 - 16:27:07 +0000)
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 29C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 1, FSL_SDHC: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
MISSING TORADEX CONFIG BLOCK
Model: Toradex Colibri iMX7D
SEC0: RNG instantiated
Net: eth0: ethernet@30be0000
MMC: no card present
switch to partitions #0, OK
** No partition table - mmc 0 **
starting USB...
Bus usb@30b10000: USB EHCI 1.00
Bus usb@30b20000: USB EHCI 1.00
scanning bus usb@30b10000 for devices... 1 USB Device(s) found
scanning bus usb@30b20000 for devices... 4 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
ethernet@30be0000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@30be0000
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
When we try load the New OS with evaluation board we are getting below messages
USB EHCI 1.00
SDP: initialize...
SDP: handle requests...
Downloading file of size 33458128 to 0x82100000... done
Downloading file of size 378 to 0x82000000... done
Jumping to header at 0x82000000
Header Tag is not an IMX image
## Loading kernel from FIT Image at 82100000 ...
Using 'config@imx7d-colibri-emmc-eval-v3.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x82100108
Data Size: 6984192 Bytes = 6.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x81000000
Entry Point: 0x81000000
Hash algo: sha1
Hash value: 490dccdf06b3dec19f8110a3270114559fc46eb2
Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 82100000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Data Start: 0x827ef8fc
Data Size: 26181632 Bytes = 25 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: e566d335fb634e03c202f4c232a16cae26fc8a96
## Loading fdt from FIT Image at 82100000 ...
Trying 'fdt@imx7d-colibri-emmc-eval-v3.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x827c40ac
Data Size: 56238 Bytes = 54.9 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 5c7c209a9f79b3c2cecf5bd72fc2c9209b38d2f9
Booting using the fdt blob at 0x827c40ac
EHCI failed to shut down host controller.
Loading Kernel Image
Loading Device Tree to 8ffef000, end 8ffffbad ... OK
Starting kernel ...
[ 0.027088] debugfs: Directory 'dummy-iomuxc-gpr@30340000' with parent 'regmap' already present!
[ 0.257287] debugfs: Directory 'dummy-src@30390000' with parent 'regmap' already present!
[ 0.334023] fec 30be0000.ethernet: Invalid MAC address: 00:00:00:00:00:00
[ 0.378724] CPUidle arm: CPU 0 failed to init idle CPU ops
Running /etc/rc.local...
Toradex Easy Installer 5.5.0+build.6 ()
Starting udev
[ 12.001885] mmc0: Timeout waiting for hardware interrupt.
[ 12.007291] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 12.013734] mmc0: sdhci: Sys addr: 0x822af000 | Version: 0x00000002
[ 12.020176] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000008
[ 12.026618] mmc0: sdhci: Argument: 0x003ab780 | Trn mode: 0x0000003b
[ 12.033060] mmc0: sdhci: Present: 0x01f8820e | Host ctl: 0x00000031
[ 12.039502] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 12.045943] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000007f
[ 12.052385] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 12.058826] mmc0: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 12.065267] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000302
[ 12.071709] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 12.078151] mmc0: sdhci: Cmd: 0x0000123a | Max curr: 0x00ffffff
[ 12.084593] mmc0: sdhci: Resp[0]: 0x80000900 | Resp[1]: 0x7ff6db80
[ 12.091034] mmc0: sdhci: Resp[2]: 0x320f5900 | Resp[3]: 0x00000900
[ 12.097475] mmc0: sdhci: Host ctl2: 0x00000008
[ 12.101920] mmc0: sdhci: ADMA Err: 0x00000003 | ADMA Ptr: 0xac597204
[ 12.108360] mmc0: sdhci: ============================================
[ 22.241874] mmc0: Timeout waiting for hardware interrupt.
[ 22.247278] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 22.253721] mmc0: sdhci: Sys addr: 0x822af000 | Version: 0x00000002
[ 22.260163] mmc0: sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000008
[ 22.266604] mmc0: sdhci: Argument: 0x003ab780 | Trn mode: 0x0000003b
[ 22.273045] mmc0: sdhci: Present: 0x01f8820e | Host ctl: 0x00000031
[ 22.279487] mmc0: sdhci: Power: 0x00000002 | Blk gap: 0x00000080
[ 22.285928] mmc0: sdhci: Wake-up: 0x00000008 | Clock: 0x0000007f
[ 22.292369] mmc0: sdhci: Timeout: 0x0000008f | Int stat: 0x00000000
[ 22.298811] mmc0: sdhci: Int enab: 0x117f100b | Sig enab: 0x117f100b
[ 22.305252] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000302
[ 22.311694] mmc0: sdhci: Caps: 0x07eb0000 | Caps_1: 0x8000b407
[ 22.318136] mmc0: sdhci: Cmd: 0x0000123a | Max curr: 0x00ffffff
[ 22.324578] mmc0: sdhci: Resp[0]: 0x80000900 | Resp[1]: 0x7ff6db80
[ 22.331019] mmc0: sdhci: Resp[2]: 0x320f5900 | Resp[3]: 0x00000900
[ 22.337459] mmc0: sdhci: Host ctl2: 0x00000008
[ 22.341904] mmc0: sdhci: ADMA Err: 0x00000003 | ADMA Ptr: 0xac597204
[ 22.348344] mmc0: sdhci: ============================================
For u r reference we have attaching some images
Please suggest us what we have to do and why the config block is corrupting.
