Hi there,
with the LM816 as Wifi Access Point on a Colobri iMX7 we want that other Devices can join the Colobri and get serve some webpages from the Colobri.
At first is this possible ? And if yes, do you got a hint how to configure this scenario or is there a resource for this kind of information in the web. I try to figure out how it become to work but got no success.
Thx in advance.
David Korm
hi @david_korm
You can check if the Access Point is supported by launching the following command: iw phy | grep Supported -A 5 and looking for Supported interface modes. I checked with LM816 and Bsp 2.8b4. There the access Point mode is not supported.
If you are interested to get a Wifi Solution with Access Point Mode, then you should use iMX6ULL.
Best regards, Jaski
Hi @jaski.tx
thank you for your answer. Unfortunately we cannot change the module. Now we got to question:
First, is the USB device which have ac Access Point Mode ?
And second, is it possible to built up with the LM816 an ad hoc network ?
And could I doing something wrong in generally:
root@colibri-imx7-emmc:~# iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
can0 no wireless extensions.
root@colibri-imx7-emmc:~# lsusb
Bus 001 Device 004: ID 1fc9:2047 NXP Semiconductors
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 006: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Is there some missing that I cant see the LM816 in iwconfig list ?
First, is the USB device which have ac Access Point Mode ? And second, is it possible to built up with the LM816 an ad hoc network ?
The features of the USB Wifi Dongle LM816 can be found at this link:
Could you provide the complete bootlog and the output of lsmod?
