I can run the two RPMsg tty and ping pong examples on the imx7 fine but when there is little free memory the kernel module will crash.
I’m using the Colibri_iMX7_LinuxImageV2.6_20160630 release on a Colibri iMX7 Solo 256MB and following the example given at FreeRTOS on the Cortex-M4 of a Colibri iMX7 | Toradex Developer Center
A simple, reproducible way to show the crash is to fill /tmp since it’s mounted as a tmpfs. In the serial console log below i run up the RPMsg TTY example fine, use dd to fill /tmp and then the next message i send causes the imx_rpmsg_tty module to crash.
root@colibri-imx7:~# modprobe imx_rpmsg_tty
[ 22.826041] imx_rpmsg_tty rpmsg0: new channel: 0x400 -> 0x0!
[ 22.838912] Install rpmsg tty driver!
root@colibri-imx7:~# stty -F /dev/ttyRPMSG -echo
root@colibri-imx7:~# exec 3<> /dev/ttyRPMSG
root@colibri-imx7:~# echo Test >&3
root@colibri-imx7:~# cat <&3
Test
^C
root@colibri-imx7:~# free
total used free shared buff/cache available
Mem: 250164 65116 142976 704 42072 167448
Swap: 0 0 0
root@colibri-imx7:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
ubi0:rootfs 444980 145832 299148 33% /
devtmpfs 59388 4 59384 0% /dev
tmpfs 125080 0 125080 0% /dev/shm
tmpfs 125080 312 124768 0% /run
tmpfs 125080 0 125080 0% /sys/fs/cgroup
tmpfs 125080 4 125076 0% /tmp
tmpfs 125080 0 125080 0% /var/volatile
/dev/mmcblk0p1 524008 103696 420312 20% /media/mmcblk0p1
tmpfs 25020 0 25020 0% /run/user/0
root@colibri-imx7:~# dd if=/dev/urandom of=/tmp/random.bin bs=1M
dd: writing '/tmp/random.bin': No space left on device
124+0 records in
122+1 records out
Mem: 250164 65336 17392 125876 167436 41988
Swap: 0 0 0
ubi0:rootfs 444980 146132 298848 33% /
tmpfs 125080 316 124764 0% /run
tmpfs 125080 125080 0 100% /tmp
[ 435.266193] Unable to handle kernel paging request at virtual address 9083f4ac
[ 435.273422] pgd = 86cb0000
[ 435.276181] [9083f4ac] *pgd=86000811, *pte=00000000, *ppte=00000000
[ 435.282498] Internal error: Oops: 807 [#1] SMP ARM
[ 435.287290] Modules linked in: imx_rpmsg_tty usb_f_rndis u_ether usb_f_acm u_serial mcp251x can_dev libcomposite configfs
[ 435.298385] CPU: 0 PID: 593 Comm: sh Not tainted 4.1.15-v2.6b2+g0ff849d #1
[ 435.305261] Hardware name: Freescale i.MX7 Dual (Device Tree)
[ 435.311010] task: 86c3e4c0 ti: 86c96000 task.ti: 86c96000
[ 435.316421] PC is at virtqueue_add_outbuf+0xbc/0x250
[ 435.321392] LR is at rpmsg_send_offchannel_raw+0x270/0x32c
[ 435.326883] pc : [<8032c914>] lr : [<804a2858>] psr: a00e0013
[ 435.326883] sp : 86c97da8 ip : 000000d0 fp : 86185000
[ 435.338363] r10: 808b97c4 r9 : 00000001 r8 : 809441b4
[ 435.343591] r7 : 9083c000 r6 : 0000034a r5 : 9083f4a0 r4 : 86c97e0c
[ 435.350121] r3 : 87dba000 r2 : 000000fb r1 : 00080000 r0 : 86c97e0c
[ 435.356652] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 435.363791] Control: 10c5387d Table: 86cb006a DAC: 00000015
[ 435.369539] Process sh (pid: 593, stack limit = 0x86c96210)
[ 435.375114] Stack: (0x86c97da8 to 0x86c98000)
[ 435.379479] 7da0: 600d0013 0000034a 88060800 00000000 0000000a 00000000
[ 435.387663] 7dc0: 00000001 88060800 8615fc00 00000012 8615fc20 8658c600 0000000a 804a2858
[ 435.395847] 7de0: 000000d0 88060800 00000012 00000001 00000014 00000001 86190608 00000400
[ 435.404032] 7e00: 00000000 807bea38 00000000 87ebac02 00000800 00000012 00000000 00000014
[ 435.412217] 7e20: 00000000 00000002 86190600 807bec28 00000001 00000002 806502c4 8658c600
[ 435.420401] 7e40: 0000000a 7f04b1a0 00000002 00000001 00000004 86655000 00000001 865a5004
[ 435.428586] 7e60: 90c6e274 00002274 806502c4 803394c8 86655000 8033a60c 865a5000 86655080
[ 435.436770] 7e80: 86c96000 8665518c 000a3a04 00000000 86c3e4c0 8005e5c0 86655190 86655190
[ 435.444955] 7ea0: 8785a380 00000005 86655000 76f76000 00000005 86c96000 8658c600 00000000
[ 435.453139] 7ec0: 8033a404 80336ccc 8782db40 00000005 000a3a04 8658c600 80336b5c 76f76000
[ 435.461324] 7ee0: 86c97f88 8000f444 86c96000 00000000 000a3a10 800e7d58 76f76000 86c97fb0
[ 435.469508] 7f00: fffffffc 00000000 7ed0d99c 80009268 00000002 00000000 808b4084 7ed0d1f4
[ 435.477693] 7f20: 87c3e1a0 8657b480 00000000 7ed0d1f4 86c96000 800f8f90 00000000 8657b480
[ 435.485877] 7f40: ffffe000 8658c600 00000005 76f76000 86c97f88 8000f444 86c96000 800e85f0
[ 435.494061] 7f60: 8657b480 00000000 00000001 8658c600 8658c600 76f76000 00000005 8000f444
[ 435.502246] 7f80: 86c96000 800e8eb8 00000000 00000000 00d49640 00000005 76f76000 76f17d60
[ 435.510431] 7fa0: 00000004 8000f2c0 00000005 76f76000 00000001 76f76000 00000005 00000000
[ 435.518615] 7fc0: 00000005 76f76000 76f17d60 00000004 00000005 000a6414 00086598 000a3a10
[ 435.526799] 7fe0: 00000000 7ed0d94c 76e43818 76e9ce20 600e0010 00000001 412ca838 21ad5129
[ 435.534994] [<8032c914>] (virtqueue_add_outbuf) from [<804a2858>] (rpmsg_send_offchannel_raw+0x270/0x32c)
[ 435.544578] [<804a2858>] (rpmsg_send_offchannel_raw) from [<7f04b1a0>] (rpmsgtty_write+0x5c/0xb4 [imx_rpmsg_tty])
[ 435.554858] [<7f04b1a0>] (rpmsgtty_write [imx_rpmsg_tty]) from [<803394c8>] (do_output_char+0x15c/0x1f4)
[ 435.564348] [<803394c8>] (do_output_char) from [<8033a60c>] (n_tty_write+0x208/0x4bc)
[ 435.572186] [<8033a60c>] (n_tty_write) from [<80336ccc>] (tty_write+0x170/0x294)
[ 435.579593] [<80336ccc>] (tty_write) from [<800e7d58>] (__vfs_write+0x1c/0xd8)
[ 435.586824] [<800e7d58>] (__vfs_write) from [<800e85f0>] (vfs_write+0x90/0x19c)
[ 435.594141] [<800e85f0>] (vfs_write) from [<800e8eb8>] (SyS_write+0x44/0x9c)
[ 435.601201] [<800e8eb8>] (SyS_write) from [<8000f2c0>] (ret_fast_syscall+0x0/0x3c)
[ 435.608778] Code: e0875206 e5983000 e59a1000 e1a00004 (e1c590bc)
[ 435.614959] ---[ end trace 64724adfa2ce3c6e ]---
Has anyone else seen this issue?
Martin
