Config block: ss.enable=1 and registry: [HKLM\Drivers\Display\Colibri] UseSplashSettings = 1 (or = 0) all is ok, the system is booting up.
Config block: ss.enable=0 and registry: [HKLM\Drivers\Display\Colibri] UseSplashSettings = 0 no Bootlogo visible (ok), but the system is not booting. I changed the registry in the flash memory.
Do you have any suggestions?
