Hello Team,
Is there a power consumption test for Colibri IMX6ULL 512MB WB IT V1.1 A ?.
Hello Team,
Hi @kavya
The results for the typical power consumption tests are reported at the section 9.2 Electrical Characteristics of the Datasheet of the SoM.
Do you need any additional Information?
Hello @jaski.tx ,
Yes, that is what i was looking for . Thank you.
Also , If i need to measure the power consumption of IMX6ULL with an Iris carrier board , can i measure the current across the supply directly ? or should i use sense resistors ?
Hi @kavya
It depends on what exactly you want to measure. Just the power supply of the module to design your carrier board or measure the power consumption of your complete product including carrier board with external peripherals?
Hi @jaski.tx ,
I want to measure the power consumption of my module with the carrier board , with and without peripherals.
If you want to measure the power consumption of the module with the carrier board, then you can measure the current across the power supply of carrier board.
