Dear community,
I am trying to enable uart4 and uart8 on colibri-imx6ull module.
Here is my dtb customization: link text .
After flashing the dtb /dev/ttymxc7 is present but I can’t see /dev/ttymxc3 (that should correspond to uart4.
Are there something related to pinmux problem reported here: link text ?
Thank you for the support,
Stefano.
Hi @Stefano
Could you provide the version of the Software of your module?
Please share the dmesg log in a text file?
What is the output of ls /dev | grep mxc ?
Hi @jaski.tx ,
I am running BSP 2.8 with kernel 4.9.166 (branch toradex_4.9-2.3.x-imx).
Here is the dmesg link text
root@boxio-00142D61A27C:~# ls -l /dev/ | grep mxc
crw------- 1 configur tty 207, 16 Nov 28 14:07 ttymxc0
crw------- 1 root root 207, 17 Nov 28 14:00 ttymxc1
crw-rw---- 1 root tty 207, 20 Nov 28 14:00 ttymxc4
crw------- 1 root root 207, 23 Nov 28 14:00 ttymxc7
Best,
Stefano.
Hi Stefano
Thanks for the Information.
[ 0.949414] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_UART4_TX_DATA already requested by 21a0000.i2c; cannot claim for 21f0000.serial
[ 0.961930] imx6ul-pinctrl 20e0000.iomuxc: pin-45 (21f0000.serial) status -22
[ 0.969218] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 45 (MX6UL_PAD_UART4_TX_DATA) from group uart4-grp on device 20e0000.iomuxc
You have pin-muxing errors, which you need to correct them.
Hi @jaski.tx ,
Thank you very much for the hint.
From your point of view what I need to disable in order to use the requested pin?
I thought that deleting i2c1 node in my dtb with
/delete-node/i2c1;
was enough…
Best,
Stefano.
Hi @Stefano
Usually I use the `status = “disabled” ’ Property, but I just checked the documentation and I think, it should be
/delete-node / &i2c1;
Hi @jaski.tx ,
thank you for the help.
Finally I delete the property inside the group. Here is the code:
pinctrl_hog_2: hoggrp-2 {
/delete-property/ fsl,pins;
pinctrl_ecspi1_cs: ecspi1_cs_grp {
pinctrl_ecspi1: ecspi1grp {
And it works.
Next time I will try the status disabled as you suggesst.
Thank you again.
Stefano.
