I have no application case but must ensure that the system support bluetooth 4.2 as your specification indicates. HW Version: Colibri iMX6ULL 512MB WB IT V1.0A
Thanks for this Information. Actually the question was about that fact if you absolutely need Bluetooth 4.2?
We looked a bit further on this issue and it seems to be a driver (software) issue, which will be solved in future. Do you have a time line when you need this feature?
BT 4.2 is requirement from the customer for the product. I have to make a decision this year. Wich part of the bluetooth driver stack is not ready for BT 4.2?
Thanks for your response.
Your link points to the Colibri iMX6ULL 512MB Wi-Fi / Bluetooth V1.1A Module.
I choose the Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.0A because its closer to the Volume Product (RoadMap NXP i.MX 6ULL Computermodule - Colibri iMX6ULL). I found no hints for the real and fully BT-Support for this Products. Your output looks also like it’s a different WLAN/BT-Chip? Is that correct?
Will come fully BT4.2 Support for the Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.0A? (for exactly this hw version)
You are welcome. Actually Colibri iMX6ULL 512MB Wi-Fi 1.0A Module was only for Development and not made for Volume Products. As you already noticed, we changed to different chip which was a better choice due to availability and Bluetooth 5.0 which will fulfil our module specification.
Unfortunately there is no update planned for HW version 1.0A to support BT4.2. Anyhow this version is also not planned for end customer. You should wait for the HW 1.1A, which should be available at the end of November 2018.
