Hi Kevin,
not sure, if this is what you are asking for. If you are looking for more detail, I need some guidance on how to provide that.
Thanks,
Siegfried
root@colibri-imx6-10801658:~# /usr/bin/gst-launch-1.0 v4l2src -v device=/dev/video0 ! 'image/jpeg, width=1280, height=720' ! vpudec output-format=4 ! imxv4l2sink overlay-width=640 overlay-height=480 device=/dev/video16
[INFO] Product Info: i.MX6Q/D/S
====== IMXV4L2SINK: 4.5.7 build on Nov 13 2020 08:36:18. ======
Setting pipeline to PAUSED ...
display(/dev/fb0) resolution is (640x480).
====== VPUDEC: 4.5.7 build on Nov 13 2020 08:36:18. ======
wrapper: 3.0.0 (VPUWRAPPER_ARM_LINUX Build on Aug 17 2020 07:03:22)
vpulib: 5.4.39
firmware: 3.1.1.46076
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
[INFO] bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
/GstPipeline:pipeline0/GstVpuDec:vpudec0.GstPad:sink: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)2:4:7:1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstVpuDec:vpudec0.GstPad:src: caps = video/x-raw, format=(string)Y42B, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstImxV4l2Sink:imxv4l2sink0.GstPad:sink: caps = video/x-raw, format=(string)Y42B, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:7:1, framerate=(fraction)60/1
v4l2sink need allocate 3 buffers.
[ 350.579295] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 64,16,80 v_sync,l,u: 4,3,13 pixclock=23750000 Hz
Caught SIGSEGV
exec gdb failed: No such file or directory
Spinning. Please run 'gdb gst-launch-1.0 614' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:06.452933531
Setting pipeline to READY ...
[ 355.945458] mxc_sdc_fb fb@0: 640x480 h_sync,r,l: 64,16,80 v_sync,l,u: 4,3,13 pixclock=23750000 Hz
^C
