Colibri imx6 audio output
We have 6 IMX6DL modules flashed with the same WEC image and we have the following issue trying to use two audio outputs on our board (speaker/buzzer and 3.5mm headphones):
One module works for both speaker/buzzer and headphones
One neither speaker/buzzer and headphone works
Three only headphones works
Please let us know what the issue is.
We have an issue with output volume being quite low,
there is a fix that allows you to increase it using a registry key:
http://developer.toradex.com/software/windows-embedded-compact/imx6-wec-software/release-details?view=release-notes&issue=16397
