I switched my SOM from Colibri T30 to Colibri iMX6DL 512MB V1.1A and now my display stays dark.
I managed to install a Toradex default Windows Embedded Compact 2013 image using the pre-installed Toradex Easy Installer despite seeing almost nothing but it’s still dark.
Seeing nothing makes it hard to debug this issue…
I can set the display brightness on the T30 using this C# function, but it doesn’t work on the iMX6 and I haven’t found out what are the correct settings for it to work.
public const int TEGRA3_PRESCALE_5kHz = 70; | ||
public const int TEGRA_PERIOD = 256; | ||
public const Int32 PWM_A = 59; |
public static void DisplayBrightnessT30(uint brightness)
var altFunctionA = 1;
var channel_a = 0;
if (!_runPMW)
NativeMethods.InitGPIOLib();
NativeMethods.SetPinLevel(30, 0);
NativeMethods.SetPinAltFn(71, -1, true);
NativeMethods.SetPinAltFn(NativeDefinitions.PWM_A, altFunctionA, true);
NativeMethods.InitPWM(channel_a, TEGRA3_PRESCALE_5kHz, TEGRA_PERIOD);
_runPMW = true;
NativeMethods.SetPWMDutyPercentage(channel_a, (int)brightness);
Any advice would be greatly appreciated!
