Colibri i.MX8DX - Configure Device Tree for RS-485 and GPIO RTS
Good morning,
I am using a Yocto build using kernel colibri-imx8x 5.15.148-6.4.0+git.284966e8d6ee
I have been trying to configure lpuart1 for RS-485 half duplex
	fsl,pins =  <IMX8QXP_UART1_RX_ADMA_UART1_RX             0x00000020>,
				<IMX8QXP_UART1_TX_ADMA_UART1_TX              0x00000020>,
				<IMX8QXP_SCU_GPIO0_00_LSIO_GPIO2_IO03       	 0x00000020>;		/* SODIMM  144 */
  • I have removed the pin conflict of SODIMM 144
&lpuart1 {
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_uart1>;
	rts-gpios = <&lsio_gpio2 3 GPIO_ACTIVE_HIGH>;
	rs485-rts-delay = <0 0>;
	linux,rs485-enabled-at-boot-time;
    status= "okay";
  • When I build and run the code, pin 144 is always high when transmitting. It never transitions low.
  • I rebuilt a new image with libgpiod and gpio tools and issued gpioinfo. It indicates that SODIMM_144 is configured as an input
Can someone assist on how to configure SODIMM_144 as an output for the data enable (RTS) for RS-485 as described above?
:handshake:
To configure SODIMM 144 as an output for the RTS signal in RS-485 mode, you need to ensure that the pin is correctly muxed and configured in the device tree. Here are the steps to achieve this:
  1. Pin Multiplexing Configuration:
    Ensure that the pin is correctly muxed as a GPIO in the pinctrl node. Your current configuration seems correct, but let’s double-check it:
    pinctrl_uart1: uart1grp {
  2. UART Configuration:
    Ensure that the UART node is correctly configured to use the RTS pin for RS-485:
    &lpuart1 {
  3. GPIO Configuration:
    Ensure that the GPIO is correctly configured as an output. You can add a GPIO configuration node to explicitly set the direction of the GPIO:
    &lsio_gpio2 {
        gpio-controller;
        #gpio-cells = <2>;
        pinctrl-0 = <&pinctrl_gpio2>;
    pinctrl_gpio2: gpio2grp {
        fsl,pins = <IMX8QXP_SCU_GPIO0_00_LSIO_GPIO2_IO03 0x00000020>;
  4. Device Tree Overlay:
    If you are using a device tree overlay, ensure that the overlay is correctly applied and does not conflict with other configurations.
  5. Rebuild and Deploy:
    Rebuild your device tree and deploy it to the target device. Ensure that the new device tree is being used by the kernel.
hey @cowboydan,
Looking at the device tree for the SODIMM 144 pin and imx8 colibri, this pin is to be used in SCFW, so I don’t believe its a good choice for your RTS if other pins are available.
   1      * This pin is used in the SCFW as a UART. Using it from
   2      * Linux would require rewritting the SCFW board file.
   3      */
   4     pinctrl_hog_scfw: hogscfwgrp {
   5         fsl,pins = <IMX8QXP_SCU_GPIO0_00_LSIO_GPIO2_IO03        0x20>;      /* SODIMM 144 */
   6     };
And looking at the RS485 device tree bindings yaml, I see rs485 as being built in half duplex. So when you enable at boot, this should indicate the half duplex.
-Eric
Hi @eric.tx ,
Understood and agree re: pin 144. We do not need that pin and I have resolved that conflict.
Do you or does anybody know just for proof-of-concept if Toradex has an example demo for use with the Colibri Evaluation board that exercises its RS-485 connection?
Hey @cowboydan,
I don’t have a Toradex demo example for rs485 readily available, but I did find another resolved ticket with a script inside that appears to be working from the customers perspective.
-Eric
Hi @eric.tx
UPDATE Ultimately we ended up implementing our own userspace client that uses the Linux DT Binding for RS-485 so that it has control over the RTS/DE with much faster response time than using GPIO from userspace.
Thanks for your help!
Hey @cowboydan,
Thanks for the update. And I’m glad you have a fast solution!
-Eric
Hey @cowboydan
Just curious…so you abandoned the rts control built into the serial drivers and now just use the rx/tx functionality there coupled with a userspace client to toggle the gpio when applicable?
Hey @DaveM
The reverse - we abandoned user-mode GPIO control of RTS (latency ~4msec after end of transmission before RTS was de-asserted) to the native control of RTS build into the drivers (latency ~tens of microseconds). The problem was a collision with the client reply whilst our RTS was enabled and the data not being received. We couldn’t live with a workaround of a “pause” period between transmit/receive, so the native driver control of RTS seems to work well for us.
Ah…when you said “userspace client”, I leapt to “toggle gpio”, “sent data”, “toggle gpio”, “receive data”. Tough timing there :wink:
So your pin config for that signal connected to your 485 driver is _RTS or is it _GPIO? I’m interpreting your comment above as you’ve changed to “native” _RTS, thus having uart-has-rtscts in the device tree (as opposed to having rts-gpios in there?)
Correct. We are using a GPIO pin configured as RTS, but not through the GPIO API if that makes sense. (Not sure I have the right vocabulary words).
