Hi !
Following my post on colibri i.MX7 (see Using OpenOCD with imx7/colibri - Technical Support - Toradex Community) I can now reset and halt my A7 using the jtag connexion, early enough to debug my code (thanks again !).
However, when I’m trying to set a hardware break point to reach my actual issue, I get the following error
no hardware breakpoint available
can't add breakpoint: resource not available
Failure setting breakpoint, the same address(IVA) is already used
Here is a full log of my attempt:
# OpenOCD terminal
$ sudo openocd -f tcl/interface/ftdi/dp_busblaster.cfg -f tcl/board/nxp_imx7sabre.cfg
Open On-Chip Debugger 0.10.0+dev-00403-g3737dd6 (2018-04-23-09:42)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : If you need SWD support, flash KT-Link buffer from https://github.com/bharrisau/busblaster
and use dp_busblaster_kt-link.cfg instead
adapter speed: 1000 kHz
srst_only separate srst_gates_jtag srst_push_pull connect_deassert_srst
adapter_nsrst_assert_width: 100
adapter_nsrst_delay: 10
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1000 kHz
Info : JTAG tap: imx7.cpu tap/device found: 0x5ba00477 (mfg: 0x23b (ARM Ltd.), part: 0xba00, ver: 0x5)
Info : imx7.cpu_a7.0: hardware has 6 breakpoints, 4 watchpoints
Info : Listening on port 3333 for gdb connections
Info : Listening on port 3334 for gdb connections
Info : accepting 'telnet' connection on tcp/4444
Error: Target not halted
pc (/32): 0x00000000
Error: Debug regions are unpowered, an unexpected reset might have happened
Error: JTAG-DP STICKY ERROR
Info : Deferring arp_examine of imx7.cpu_a7.1
Info : Use arp_examine command to examine it manually!
Info : Deferring arp_examine of imx7.cpu_m4
Warn : imx7.cpu_a7.0: ran after reset and before halt ...
Warn : imx7.cpu_a7.1: ran after reset and before halt ...
Info : imx7.cpu_a7.0 rev 5, partnum c07, arch f, variant 0, implementor 41
Info : imx7.cpu_a7.0 cluster 0 core 0 multi core
target halted in Thumb state due to debug-request, current mode: Supervisor
cpsr: 0x2000a4f3 pc: 0x00920aea
MMU: disabled, D-Cache: disabled, I-Cache: enabled
memory bus access delay set to 0 tck
pc (/32): 0x00920AEA
Error: Invalid command argument
length option value ('hw') is not valid
Info : no hardware breakpoint available
Error: can't add breakpoint: resource not available
Error: Failure setting breakpoint, the same address(IVA) is already used
# Telnet terminal
$ telnet localhost 4444
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
> reg pc
Target not halted
> reset init
> reg pc
> bp 0x00920AEA hw
> bp 0x00920AEA 4 hw
> bp 0x00920AEA 1 hw
Openocd advertizes 6 breakpoints, but I can’t manage to set even one. How should I do it ?
My configuration is the one described in the previous post, patched with @dominik.tx answers
