I did Erase Flash on Tordex Easy Installer, After reboot I am not getting any thing on the display or Serial Debug console, I need to flash the Linux image to eMMC / SD Card,
Can you please help me in doing the same.
I have generated the build named " Colibri-iMX7-eMMC_Reference-Minimal-Image.rootfs.bootfs.tar.xz" OR " Colibri-iMX7-eMMC_Reference-Minimal-Image.rootfs.tar.xz
" OR “Colibri-iMX7-eMMC_Reference-Minimal-Image.rootfs.wic.gz”
I need to flash these images to eMMC either using SD Card / USB, How can I flash the above build to eMMC?
Can you please let us know which BSP version your build is based on. Our recent BSP is BSP 5.x. When you successfully run bitbake . The output Linux image will be available in deploy/images directory
For Colibri iMX7D 1GB eMMC
oe-core-5.0/build/deploy/images/colibri-imx7-emmc
And the Linux image name is as below
ls | grep -i Tezi
Colibri-iMX7-eMMC_Custom-Console-Image-Tezi_5.3.0-devel-20210717034726+build.0.tar
Colibri-iMX7-eMMC_Reference-Multimedia-Image-Tezi_5.3.0-devel-20210607071505+build.0.tar
These are compatible images you can use Toradex easy installer to flash on board memory of Toradex module.
In case you need to boot from external media please check below article
