Hi Team,
We are using colibri i.MX6ULL SOM module in our Project, So I need an information on required length matching details of MII signals from Ethernet switch., could you please give clarity on this.
The length matching details of the TX/RX signals of Ethernet ports from Ethernet switch is also needed., So Please suggest us any required documents for this details.
Hi Alex,
In the above document there is no proper information on length matching details of MII signals, we require the length matching details of MII signals which can be best routed on board, Could you please give exact information on this.
