Is this a typo in the datasheet? It says the barrel connector input power range is 6-12 vdc, but the terminal connector is 6-27 vdc
Yes, this appears to be an error in the datasheet. The input voltage range should indicate 7-27V DC which is stated at the beginning of section 3.2. Notice on the carrier board’s schematic that the two connectors are connected eachother.
Thanks for pointing out this discrepancy. We will get it resolved.
