DrWenz
September 22, 2022, 8:32am
1
why does the Colibri DSI to HDMI has a 24 pin FPC and not a 20pin FPC on the HDMI side?
I’m trying to evaluate the Colibri IMX8X and now i need to develop a custom adapter because mostly HDMI <-> FPC Adapter are 20pin 0.5mm FPC, I can’t find a 24 pin one.
Does anyone know a adapter for 24pin 0.5 FPC to HDMI ?
DrWenz
September 22, 2022, 8:49am
2
Ok, I think I need this too or?
Der HDMI Adapter bietet ein unkompliziertes Interfaces, um einen Full HD Monitor mit einem Colibri 2, 3, iMX6 Modul unter Verwendung des HDMI Interface zu verbinden.
Hi @DrWenz ,
Thanks for reaching out. Indeed, as you want to use the HDMI on Colibri iMX8X you’d need to have both the DSI to HDMI Adapter (Colibri iMX8X DSI to HDMI Adapter | Toradex Developer Center ) and the HDMI Adapter for Colibri modules that you’ve shared already. The Colibri iMX8X has no native HDMI interface as you can see on chapter 5.6 of its datasheet (https://docs.toradex.com/105670-colibri-imx8x-datasheet.pdf )
Does this help you?
DrWenz
September 22, 2022, 3:53pm
4
Hi @gclaudino.tx ,
thx, got it. I need the HDMI to HDMI adapter too, thanks for clarifying
Hi @DrWenz !
Glad to hear it helped
Can you please tag the post as solved then? Please feel free to add more content to it or create a new topic if you still need support.
