Exactly the same code succeeds in driving GPIO on pin 13 of the Iris Board but produces no changes
on GPIO pins 15 and 17, although they are all GPIO by default and the same code is used for the three attempts…
Any ideas?
See the code below:
Init first
hGpio = Gpio_Init((Int32*)0);
Gpio_Open(hGpio);
Now toggle pin 15
io = ((0x0020 << 16) + 103); // Colibri SODIMM pin 103 (Iris pin 15)
Gpio_ConfigureAsGpio(hGpio, io); // Configure io as GPIO
Gpio_SetDir(hGpio, io, 1); // Set GPIO Configured io as output
Gpio_SetLevel(hGpio, io, 1); //set output to 1
Gpio_SetLevel(hGpio, io, 0); //set output to 0
Didn’t work
Now try on 13
io = ((0x0020 << 16) + 98); // Colibri SODIMM pin 98 (Iris pin 13)
Success!!
Now try on 17
io = ((0x0020 << 16) + 97); // Colibri SODIMM pin 97 (Iris pin 17)
I quickly tried to reproduce this issue. I quickly rewrote the code a little bit, may be it is related to this. I was able to reproduce this issue. Please check with my code and make sure you are using the latest lib as well (I have used the 2.0 release)
Here my code:
HANDLE hGpio = Gpio_Init(NULL);
uIo io ;
Gpio_Open(hGpio);
//Now toggle pin 15
io.GenericDefinition = IOCOLIBRIPIN(103); // Colibri SODIMM pin 103 (Iris pin 15)
Gpio_SetDir(hGpio, io, ioOutput); // Set GPIO Configured io as output
Gpio_SetLevel(hGpio, io, ioHigh); //set output to 1
Gpio_SetLevel(hGpio, io, ioLow); //set output to 0
//Now try on 13
io.GenericDefinition = IOCOLIBRIPIN(98); // Colibri SODIMM pin 98 (Iris pin 13)
//Now try on 17
io.GenericDefinition= IOCOLIBRIPIN(97); // Colibri SODIMM pin 97 (Iris pin 17)
return 0;
@Henry: If you use Gpio_ConfigureAsGpio with the latest lib, it automatically should de-tristate the pin. If this workarround is still used, there is something wrong. Let me know if you need any further help.
