Hi we are working on Apalis Imx6q V1.0. we have a question that we tried to find out but some how we not able to solve it.
- we have created a dummy driver so that without using codec we would study the change in frequency(on oscilloscope) so we did modification in apalis-imx6.dtsi according to this link I2S output on Apalis i.MX6 - Technical Support - Toradex Community
and also we did some registers modification using memtool by running this shell script.
/unit_tests/memtool -32 0x020C8078=0x00011006
/unit_tests/memtool -32 0x020C8074=0x00011006
/unit_tests/memtool -32 0x020C401C=0x00900000
/unit_tests/memtool -32 0X020C4028=0x0EC102C1
/unit_tests/memtool -32 0x020C4060=Ox000000fb
/unit_tests/memtool -32 0x0202801C=0x00000200
/unit_tests/memtool -32 0x02028020=0x00000200
/unit_tests/memtool -32 0x02028010=0x00000000
/unit_tests/memtool -32 0x020c817c=0x00672f67
/unit_tests/memtool -32 0x020c8174=0x00672f67
/unit_tests/memtool -32 0x020c8178=0x00672f67
so coming to the main point at last, we are not able generate Bit_clock(194 pin) and MCLK(200 pin) but it is showing pure DC with some voltage on oscilloscope and sometimes it get increase by few volts after running this script(this happens some times only), please let me know that if my path is correct or not to generate the clock across the BIT_CLK and MCLK in Apalis imx6 Eval v1.0 board
thank-you
