Hi, I’m building a custom Yocto image for the Verdin i.MX8MP module using the Scarthgap release. The image is based on tdx-reference-minimal-image.bb, and my goal is to include the Chromium browser with graphical support using Wayland and X11.
I’m using the default DISTRO_FEATURES (which includes Wayland), and the image boots successfully. However, when I launch chromium-browser from the terminal, I encounter the following issue:
- The screen remains blank or empty
- Multiple errors appear in the terminal
- Chromium does not display its user interface
How can I resolve this issue and get Chromium running correctly with graphical output?
Any suggestions or guidance would be appreciated.
Thanks!
Hello! Thank you for your detailed explanation.
To get Chromium running with graphical support on your Verdin iMX8MP using Yocto and the Scarthgap release, there are a few key steps and considerations:
1. Include the Correct Chromium Variant and Dependencies
The recommended Chromium package for Wayland is chromium-ozone-wayland. Add the following to your local.conf:
CORE_IMAGE_EXTRA_INSTALL += "chromium-ozone-wayland"
LICENSE_FLAGS_ACCEPTED += "commercial_libav commercial_x264"
This ensures Chromium is built with the correct back-end and its required licenses are accepted.
See reference:
2. Check Which Display Server Is Running
- If Wayland is running (which is default for Verdin i.MX8MP), use the Wayland-optimized launch options.
- If using X11, additional steps are required, and performance may be suboptimal.
3. Launch Chromium with Appropriate Arguments
Wayland is recommended for proper GPU acceleration on i.MX8 platforms.
4. GPU Acceleration Support
- The last Chromium version confirmed to work with GPU on i.MX is v117. Later versions may not provide GPU acceleration.
- To avoid launch problems related to sandboxing, add the
--no-sandbox flag.
- Ensure you’re not SSH-ing in without an active graphical session; Chromium needs to launch inside the appropriate graphical desktop session.
5. Blank Screen & Errors
Common causes include:
- Missing or misconfigured Wayland/X11 session (ensure
weston or a Wayland compositor is running).
- Using incompatible Chromium version (always check for v117 or below for hardware acceleration).
- Permissions (try running as root or check user access to
/dev/dri and the display socket).
6. Troubleshooting
7. HTML Output Check
Once running, test hardware acceleration by visiting chrome://gpu in Chromium.
References
If you provide the exact errors you’re seeing, a more specific solution can be suggested.
Hi @nidhishende ,
I hope you were able to solve the issue after following the suggestion from ToradexAI.
Let me know if otherwise.
