We incorrectly mapped the I2C using an alternate pin configuration and therefore cannot use the default base image.
Please find the mapping we have -
I2C1 SCL – pin 96
I2C1 SDA – pin 75
I2C2 SCL – pin 88
I2C2 SDA – pin 86
I2C3 SCL – pin 81
I2C3 SDA – pin 94
When we use the GPIO tool to set Pin 96 and Pin 75 we cannot find any devices using the I2C tool. When we put a scope on the clock line we see the line stay low until it times out then goes high.
Any suggestions?
Thanks,
Matt
Dear @mfratkin
Background
Let me give you some background information to explain why there is a problem:
On the iMX7, the library relies on underlying i2c drivers. The pin configuration can be modified at the driver load time only.
The i2c driver is loaded either
- on system boot, if the registry is configured to do so, or
- in the first call to
I2c_Open()
Pins 96 and 75 belong to the physical i.mx7-i2c instance i2c4. This is the same instance which is available on pins 194 and 196 by default (The default i2c pins for any Colibri module). The external RTC on the Evaluation Board is connected to these pins.
Because it is the default instance, we call it [HKLM\Drivers\Builtin\I2C 1] in the registry (sorry for the potential confusion).
What Happens
During System Boot, the I2C1 driver is loaded for two reasons:
- The registry entry at [HKLM\Drivers\Builtin\I2C1] is configured to load this driver
- Due to [HKLM\Init\Launch48], the rtcsync.exe tool is loaded, which would also load the I2C1 driver to communicate with the external RTC.
As the driver is already loaded when your application kicks in, you cannot change the pinout anymore.
Solution
Put the following statements into the registry
SclPin = dword:96
SclAF = dword:0
SdaPin = dword:75
SdaAF = dword:0
This will cause the system to load the driver with the correct pinout from beginning on, therefore also RtcSync.exe will use these pins to communicate with the RTC.
By the way: to check the pin multiplexing you can launch the Gpio Tool.
Andy
Hello @andy.tx ,
Thanks for the information. We made the changes and still see the clock line equally the data line and it cannot find the devices that are attached. We will look into our code again to see if there is anything off.
I am assuming we can make the same registry changes for the other I2C buses?
[HKLM\Drivers\Builtin\I2C3]
SclPin = 81
SclAF = 0
SdaPin = 94
SdaAF = 0
Thanks,
Matt
@andy.tx ,
We made a mistake on our end (set the registry’s to strings not DWORD). We now have both I2C1 and I2C3 working using the I2C demo application.
Thanks,
Matt
Dear @mfratkin
I’m glad to hear that it is working now.
I edited my previous answer and inserted the dword: in order to clarify the required type.
Regards, Andy
