Changing clock frequency for display with Verdin IM8MX Plus
Hello! Thank you for reaching out.
To set a custom pixel clock frequency for your 5" display on the Verdin iMX8M Plus with Torizon (or Linux), you need to update the display’s timing parameters using a device tree overlay. The device tree handles hardware configuration at boot, including display timings like pixel clock.
Here’s how you can proceed:
1. Gather Display Timing Information
First, obtain your 5" display’s required timing parameters:
  • Pixel clock frequency (in Hz)
  • Horizontal/vertical active pixels and sync parameters
  • Sync pulse, back porch, front porch values
These should be provided in the display’s datasheet.
2. Create or Edit a Device Tree Overlay
Identify the node in the Toradex-provided device tree that matches your display interface (e.g., LVDS, DSI, RGB).
Example (for an LVDS panel):
&lcdif {
    status = "okay";
    display-timings {
        native-mode = <&timing_x>;
        timing_x: timing_x {
            clock-frequency = <your_pixel_clock>;
            hactive = <...>;
            vactive = <...>;
            hfront-porch = <...>;
            hback-porch = <...>;
            hsync-len = <...>;
            vfront-porch = <...>;
            vback-porch = <...>;
            vsync-len = <...>;
            // Add other parameters as needed.
Replace <your_pixel_clock> and the display timing values with those for your 5" display.
3. Deploy and Test
  • Add your custom overlay to /boot/overlays and list it in the overlays.txt on the boot partition if using TorizonCore.
  • Reboot your system. The driver should now initialize the pixel clock and timings according to your new parameters.
References:
If you share your existing overlay or the timing parameters you’re trying to use, I can help refine the syntax further.
