Suppose I have to switch from FTDI UART chip which can definitely cope with 1024 Bytes of max packet size
(see vybrid_usb_work.conf) to PrimeCell UART with TR/RX FIFOs of 32 bytes.
Shall I change then max packet size in the conf file to 32?
Could you provide the version of the hardware (including carrier board) and software of your module?
Suppose I have to switch from FTDI UART chip which can definitely cope with 1024 Bytes of max packet size (see vybrid_usb_work.conf) to PrimeCell UART with TR/RX FIFOs of 32 bytes.
Why do you need to switch? What is the purpose of this Prime Cell UART chip?
Why do you want to do that? Did you see any issues till now?
This is a self made board. Part of it has been already tested on a amd64 machine.
Now we want to make the already tested part work also on aarch64.
The Prime Cell UART chip is the UART chip which governs UART on our aarch64 board.
I am at the beginning of my investigation and just want to exclude any possible errors.
