I am using Linux colibri-imx8x-06858732 with TorizonCore 5.4.193-rt74-5.7.0. Im is trying to update the clock speed on i2c16 and ic17 to 400kHz to support fast i2c. I tried writing the following overlay without any success. What is the correct way to change the default clk speed of I2C interfaces?
/dts-v1/;
/plugin/;
compatible = “toradex,colibri-imx8x”;
&i2c16 {
clock-frequency = <400000>;
&i2c17 {
Hi @fjliving,
Can you please share with us the carrier board you’re using?
I believe the node for the I2C is not correct, I couldn’t find references for these nodes in our device trees. Can you please share which I2C you want to change the clock frequency?
Hiago.
I2C1 pin 194,196. I believe that is my mistake; should it be @i2c1
Hi @fjliving,
For pins 194 and 196, they are assigned to the following node:
/* Colibri I2C */
&i2c1 {
#address-cells = <1>;
#size-cells = <0>;
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c1>;
/* Atmel maxtouch controller */
atmel_mxt_ts: touchscreen@4a {
compatible = "atmel,maxtouch";
pinctrl-0 = <&pinctrl_atmel_conn>;
reg = <0x4a>;
interrupt-parent = <&lsio_gpio3>;
interrupts = <20 IRQ_TYPE_EDGE_FALLING>; /* SODIMM 107 */
reset-gpios = <&lsio_gpio3 24 GPIO_ACTIVE_HIGH>; /* SODIMM 106 */
status = "disabled";
(You can check the imx8x-colibri.dtsi file).
So your overlay should be something like this:
/dts-v1/;
/plugin/;
compatible = "toradex,colibri-imx8x";
&i2c1 {
Hiago.
