I’m trying to use the image torizon/wayland-base-am62:3 but I’m getting the following when I run an apt-get update:
Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB]
Get:2 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
Ign:4 https://feeds1.toradex.com/debian-am62/snapshots/20240516T135855Z testing InRelease
Get:5 http://deb.debian.org/debian bookworm/main arm64 Packages [8688 kB]
Get:6 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [13.7 kB]
Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [166 kB]
Err:4 https://feeds1.toradex.com/debian-am62/snapshots/20240516T135855Z testing InRelease
Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in the certificate verification. [IP: 141.95.6.232 443]
Fetched 9122 kB in 9s (963 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
27 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch https://feeds1.toradex.com/debian-am62/snapshots/20240516T135855Z/dists/testing/InRelease Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected. Could not handshake: Error in the certificate verification. [IP: 141.95.6.232 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Trying to access the Index of /debian also give me an security warning SSL_ERROR_BAD_CERT_DOMAIN.
