Capacitive touch screen display interface document for Toradex imx 6ull
Hi i have a capacitive touch display that needs to be interfaced to a colibri carrier board having the imx 6ull som , need reference document on how to do this could not find any, hence please provide a reference document I could use to get this board interfaced an y useful links much appreciate, thanks.
Hello! I’d be happy to help you interface your capacitive touch display with a Colibri carrier board using the iMX6ULL SoM.
For a step-by-step reference, Toradex provides a comprehensive guide specifically for connecting the 7” capacitive touch display to Colibri carrier boards. The main resource is here:
Key points from the guide:
  • On the Colibri Aster carrier board, you can use the on-board Capacitive Touch Interface connector (X24) directly—no extra adapters are required.
  • For other carrier boards (Evaluation Board, Iris, Viola), you need the Capacitive Touch Adapter, with detailed pin-to-pin connections provided in the guide.
  • Pinout and cabling diagrams, as well as required device tree settings for enabling the touch controller, are included.
Product details (including cables and controller information) can be found here:
These documents cover hardware setup and links out to software configuration steps as well. If you need help with the device tree configuration or Linux integration, let me know!
Hey @vi007 !
The documents the AI Bot provided are accurate for your use case, let us know if you manage to follow them and feel free to reach out if you run into any issues during your setup!
yes i need help with device tree configuration
@vi007, the customization needed is on the page the bot has linked, specifically on this section for the module you are using. That section also links to the guide on how to customize the Device Tree.
