Hi all
hope you are all well!
I am currently trying to add a touch control to TorizonCore 5.7.
The Touchscreen is a custom made 7inch panel which comes with a I2C touch controller from Ilitek, ili2511.
The Linux Kernel seems to have a driver for this, although it is not set in the config.
I used this code to create a module and compile and load it with TorizonCore Builder. Together with the following dts overlay I tried to get it running, but I seem to miss something.
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/pwm/pwm.h>;
/dts-v1/;
/plugin/;
compatible = "toradex,apalis-imx8",
"toradex,apalis-imx8qm";
&backlight {
//compatible = "pwm-backlight";
brightness-levels = <0 74 128 164 192 210 255>;
default-brightness-level = <1>;
enable-gpios = <&lsio_gpio1 4 GPIO_ACTIVE_HIGH>; /* Apalis BKL1_ON */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_bkl_on>;
pwms = <&pwm_lvds1 0 5000000 PWM_POLARITY_INVERTED>;
&{/panel-lvds} {
compatible = "panel-lvds";
backlight = <&backlight>;
data-mapping = "vesa-24";
width-mm = <154>;
height-mm = <86>;
panel-timing {
clock-frequency = <54000000>;
hactive = <1024>;
vactive = <600>;
hback-porch = <160>;
hfront-porch = <160>;
vback-porch = <23>;
vfront-porch = <12>;
hsync-len = <70>;
vsync-len = <5>;
port {
panel_lvds1_in: endpoint {
remote-endpoint = <&lvds1_out>;
&ldb2 {
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
port@1 {
reg = <1>;
lvds1_out: endpoint {
remote-endpoint = <&panel_lvds1_in>;
&pwm_lvds1 {
&i2c2 {
#address-cells = <1>;
#size-cells = <0>;
touchscreen0: ilitek@41 {
compatible = "tchip,ilitek",
"ilitek,ilitek_ts_i2c",
"ilitek_ts_i2c",
"ilitek,ili251x",
"ilitek,ili2511",
"ili251x";
reg = <0x41>;
pinctrl-0 = <&pinctrl_gpio1>, <&pinctrl_gpio2>;
interrupt-parent = <&lsio_gpio0>;
interrupts = <9 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&lsio_gpio0 8 GPIO_ACTIVE_HIGH>;
ilitek,irq-gpio = <&lsio_gpio0 9 0x0>;
ilitek,reset-gpio = <&lsio_gpio0 8 0x0>;
ilitek,vbus = "vcc_i2c";
ilitek,vdd = "vdd";
ilitek,name = "ilitek_i2c";
max-fingers = <4>;
The controller is connected using a custom Carrier board. The Touch interface is connected to the Apalis I2C1 (I2C1_SCL, I2C1_SDA) and GPIOs GPIO1 (CTP_RST) and GPIO2 (CTP_INT).
I think I missed something and maybe one of you can give me an idea or hint to where I can continue to try getting it running.
The device already shows up in evtest as input1, but tapping the screen is not recognized:
torizon@apalis-imx8-14760487:~$ evtest
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
/dev/input/event0: sc-powerkey
/dev/input/event1: ILI210x Touchscreen
Select the device event number [0-1]: 1
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "ILI210x Touchscreen"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 0
Min 0
Max 65535
Event code 1 (ABS_Y)
Value 0
Min 0
Max 65535
Event code 24 (ABS_PRESSURE)
Value 0
Min 0
Max 10
Event code 47 (ABS_MT_SLOT)
Value 0
Min 0
Max 9
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 65535
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 65535
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
Event code 58 (ABS_MT_PRESSURE)
Value 0
Min 0
Max 10
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
I can see the following when checking /dev/input:
torizon@apalis-imx8-14760487:~$ cat /dev/input/
by-path/ event0 event1 touchscreen0
And the module with the driver is loaded but seems to not be used:
Module Size Used by
ili210x 20480 0
Thank you, and best regards,
