I have toradex board colibri-imx7 with LVDS display.
I connected all wires as specified, and loaded Latest Linux BSP provided with Toradex EasyInstaller.
After installation there was one issue of screen resolution , which I could fix by setting the right resolution by following command
fw_setenv vidargs video=‘mxsfb:800x480M-16@60,pixclockpol=1’
After this I also needed to enable capacitive Touch on screen, so i followed the Toradex blog to enable the touch driver.
which said following
Touch Screen
Starting with release 2.7b4 the touch controller driver is compiled as a module, and the device tree includes a device node for the touch controller. By default, the atmel_mxt_ts@4a node is in a disabled state. To enable it, change the status property from disabled to okay. Stop U-Boot and run the command below according to your module."
As my device was imx6ull so i followed following command to enable the touch
setenv fdt_fixup ‘fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay’
After this command my board is unable to boot, I can get to prompt.
Any leads… ?
I am stuck up…Please help, I can manage with out touch for now, but I want my board to reset to factory settings…
