while trying to reproduce this issue reported by my colleague on your reference image, I noticed that I can’t revert back to the Toradex images after we’ve installed our custom yocto build on the SoM. I thought loading TEZI to the SoM would revert everything to factory, but somehow our repartitioning of the SoM seems to have broken your installer.
Here’s what I did:
- Loaded TEZI to RAM and installed it to eMMC:
Followed by power off
related output on serial console:
U-Boot 2020.04-5.6.0+git.7d1febd4af77 (Mar 28 2022 - 16:22:11 +0000)CPU: NXP i.MX8QM RevB A53 at 1200 MHzDRAM: 4 GiB
Loading Environment from MMC... *** Warning - bad CRC, using default environmentIn: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB IT V1.1C, Serial# 06945064 BuildInfo:
- SCFW 99e479ce, SECO-FW 2f7f6f59, IMX-MKIMAGE 8947fea3, ATF 835a8f6
- U-Boot 2020.04-5.6.0+git.7d1febd4af77switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for mfgtools
, using default environmentRun bootcmd_mfg: select_dt_from_module_version && fastboot 0
We are in is_imx8
Getting phy ctrl
Starting download of 3260 bytesdownloading of 3260 bytes finished
Starting download of 43 bytesdownloading of 43 bytes finished
Starting download of 106496 bytesdownloading of 106496 bytes finished
Starting download of 48193012 bytes
downloading of 48193012 bytes finished
## Executing script at 82e00000
Loading hdp firmware from 0x000000009c000000 offset 0x0000000000002000
Loading hdp firmware Complete
Bootargs: quiet video=LVDS-1:d video=HDMI-A-1:640x480-16@60D initcall_blacklist=vpu_driver_init rootfstype=squashfs root=/dev/ram autoinstall clk_ignore_unused pci=nomsi
## Loading kernel from FIT Image at 8a000000 ...
Using 'config@freescale_imx8qm-apalis-v1.1-eval.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x8a000108
Data Size: 10781184 Bytes = 10.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x96000000
Entry Point: 0x96000000
Hash algo: sha1
Hash value: 597016971ab14d4e90dde5f68803acc32513c845
Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 8a000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: tezi-initramfs
Type: RAMDisk Image
Compression: uncompressed
Data Start: 0x8ab95a4c
Data Size: 36040704 Bytes = 34.4 MiB
OS: Linux
Load Address: 0xa0000000
Entry Point: unavailable
Hash algo: sha1
Hash value: f6a05b54ec24573764ccc83225c66eab0cd1661a
Loading ramdisk from 0x8ab95a4c to 0xa0000000
## Loading fdt from FIT Image at 8a000000 ...
Trying 'fdt@freescale_imx8qm-apalis-v1.1-eval.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x8aa99efc
Data Size: 166524 Bytes = 162.6 KiB
Load Address: 0x87000000
Hash algo: sha1
Hash value: 77611d9faeccca42c671df816250f05849591373
Loading fdt from 0x8aa99efc to 0x87000000
Using 'config@apalis-imx8_hdmi_overlay.dtbo' configuration
Trying 'fdt@apalis-imx8_hdmi_overlay.dtbo' fdt subimage
Data Start: 0x8ab90cf0
Data Size: 2177 Bytes = 2.1 KiB
Load Address: 0x870f0000
Hash algo: sha1
Hash value: aaf6a25c667de18d750f7b01d9cc322dbfeda54d
Loading fdt from 0x8ab90cf0 to 0x870f0000
Booting using the fdt blob at 0x87000000
Uncompressing Kernel Image
Loading Ramdisk to fb3ef000, end fd64e000 ... OK
Loading Device Tree to 00000000fb3c3000, end 00000000fb3eea3f ... OKStarting kernel ...[ 0.147035] No BMan portals available!
[ 0.148240] No QMan portals available!
[ 0.786377] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 0.875379] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 0.876586] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 1.324352] debugfs: Directory '59050000.sai' with parent 'apalis-imx8qm-sgtl5000' already present!
[ 2.549853] imx6q-pcie 5f010000.pcie: failed to initialize host
[ 2.555815] imx6q-pcie 5f010000.pcie: unable to add pcie port.
[ 2.653924] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 2.659904] imx6q-pcie 5f000000.pcie: unable to add pcie port.
Running /etc/rc.local...
Toradex Easy Installer 5.6.0+build.9 ()
Starting udev
[ 3.370371] debugfs: Directory '59090000.sai' with parent 'imx-audio-hdmi-tx' already present!
[ 3.454067] debugfs: File 'Capture' in directory 'dapm' already present!
System time was Tue May 10 12:23:08 UTC 2022.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Tue May 10 12:23:09 UTC 2022.Welcome to the Toradex Easy InstallerThis is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using VNC. Use:
# ip addr show
to display the Ethernet IP address(es) or use USB RNDIS at IP 192.168.11.1.Check our documentation at:
https://developer.toradex.com/software/toradex-easy-installer
/ # [ 181.753004] arm-smmu 51400000.iommu: removing device with active domains!
[ 181.761860] reboot: Power down
Then I turned power on again:
U-Boot 2020.04 (Aug 20 2021 - 10:22:00 +0000)CPU: NXP i.MX8QM RevB A53 at 1200 MHzDRAM: 4 GiB
In: serial
Out: serial
Err: serial
- SCFW bc122ee1, SECO-FW d63fdb21, IMX-MKIMAGE 5138add7, ATF ec35fef
- U-Boot 2020.04switch to partitions #0, OK
Saving Environment to MMC... Writing to MMC(0)... OK
flash target is MMC:0
Net: eth0: ethernet@540000
Fastboot: Normal
Normal Boot
** Unrecognized filesystem type **
## Executing script at 83100000
Wrong image format for "source" command
Apalis iMX8 #
I get exactly the same behaviour when I try to install a reference image instead of TEZI after loading TEZI to RAM.
Any idea what’s going wrong? I would have expected that I can recover a completely bricked module by loading TEZI over USB and then installing one of your reference images?
