Can't get the new Extension to run
I get this error in the .apollox.cmd.log when starting VSC in my directory:
The xonsh in /usr/bin/xonsh is not linked to /home/steve/.local/share/pipx/venvs/xonsh/bin/xonsh, trying to relink …
Insufficient permissions to create /usr/bin/xonsh and PSSWD is not set.
I can help you troubleshoot this Torizon IDE Extension error. Before providing specific solutions, I need to understand your setup better.
Setup Information Needed
Could you please provide the following details:
  • Operating System: Which OS are you running (e.g., Ubuntu 20.04, Ubuntu 22.04, etc.)?
  • Hardware: Which Toradex hardware are you working with (e.g., Verdin iMX8M Plus, Verdin AM62, Apalis iMX8QP, etc.)?
  • Torizon OS Version: What version of Torizon OS are you running on your device?
You can get detailed information about your hardware and OS by running the tdx-info command on your device. More details are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Initial Observations
The error you’re encountering appears to be related to xonsh (a Python-based shell) permissions during the extension’s dependency installation process(1). The extension attempts to install necessary dependencies during first activation and may require sudo privileges(1).
Immediate Steps to Try
  1. Check Terminal Focus: During extension activation, ensure you’re watching the TERMINAL tab in VS Code, as other extensions might move focus away from pending installation requests(1).
  2. Verify Docker Installation: Make sure you have Docker Engine properly installed (not Docker Desktop, which isn’t officially supported)(1).
  3. Check VS Code Installation Method: Ensure VS Code wasn’t installed via Snap or Flatpak, as the IDE Extension won’t work with those installation methods(1).
Once you provide your platform details, I can give you more targeted troubleshooting steps for your specific setup.
I am running VSCode in WSL, Ubuntu 24.04. This worked fine yesterday.
Here is the log:
04-30 11:06:38.993] Activating Torizon IDE …
[04-30 11:06:38.993] Torizon IDE version :: 3.3.0
[04-30 11:06:39.911] Latest Torizon IDE published :: 3.4.100
[04-30 11:06:39.911] Telemetry is enabled
[04-30 11:06:39.911] Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you’d not like to share any information. Check: Settings - Data Collection | Toradex Developer Center
[04-30 11:06:39.911] Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
[04-30 11:06:39.911] User defined host IP address found
[04-30 11:06:39.911] Host IP address OK
[04-30 11:06:39.912] Bash as default shell OK
[04-30 11:06:39.929] Docker installed OK
[04-30 11:06:40.06] Docker running OK
[04-30 11:06:40.126] Docker compose OK
[04-30 11:06:40.627] PowerShell OK
[04-30 11:06:40.671] git OK
[04-30 11:06:40.750] dig OK
[04-30 11:06:40.771] avahi-resolve OK
[04-30 11:06:40.848] nmap OK
[04-30 11:06:40.903] iputils-ping OK
[04-30 11:06:40.914] file OK
[04-30 11:06:40.925] sshpass OK
[04-30 11:06:41.018] iproute2 OK
[04-30 11:06:41.076] rsync OK
[04-30 11:06:41.101] python3 OK
[04-30 11:06:41.110] pipx OK
[04-30 11:06:41.111] Cloning project templates
[04-30 11:06:41.111] Templates repo: GitHub - torizon/vscode-torizon-templates: VS Code Torizon Integrated Development Environment Templates · GitHub
[04-30 11:06:41.111] Templates branch: bookworm-7
[04-30 11:06:41.111] Templates tag/hash: v3.3.0
[04-30 11:06:41.136] Project templates clone of branch bookworm-7 OK
[04-30 11:06:41.838] Project templates fetched OK
[04-30 11:06:41.872] Checkout templates repo to tag origin/bookworm-7 OK
[04-30 11:06:43.021] Error trying to setup xonsh
[04-30 11:06:43.021] ERROR :: Xonsh is not installed, Xonsh is required.
[04-30 11:06:43.021] WARNING :: Project name not found in workspace metadata for single container workspace, or it matches the workspace name.
[04-30 11:06:43.023] Checking connected devices …
[04-30 11:06:43.023] Scanning Torizon devices …
[04-30 11:06:43.032] Debian bookworm packages list load OK
[04-30 11:06:43.032] Configuring debug id_rsa …
[04-30 11:06:43.032] Debug id_rsa OK
[04-30 11:06:43.032] ERROR :: Errors during the initialization of Torizon IDE Extension.
[04-30 11:06:43.033] HOUSTON WE HAVE A PROBLEM!
[04-30 11:06:43.033] PLEASE READ THE LOGS!
[04-30 11:06:43.033] ERROR :: Please share this log on https://community.toradex.com
[04-30 11:06:43.140] Checking host ip sanity …
[04-30 11:06:50.381] Host ip is OK
[04-30 11:06:50.385] Device 10.40.100.5 set as Docker Host
Issue Identified
Based on your log, the error is clear: “ERROR :: Xonsh is not installed, Xonsh is required.” This is causing the initialization failure of the Torizon IDE Extension.
Ubuntu 24.04 Compatibility Issue
The main issue is that you’re running Ubuntu 24.04 in WSL. According to the official documentation, the Torizon IDE Extension currently supports Ubuntu 22.04 for WSL environments(1). Ubuntu 24.04 is not officially supported, which explains why the xonsh dependency installation is failing.
Recommended Solutions
1. Use Supported Ubuntu Version
Switch to Ubuntu 22.04 in WSL, which is the officially supported distribution(2)(1). You can install Ubuntu 22.04 from the Microsoft Store or using:
wsl --install -d Ubuntu-22.04
2. Use the Installation Wizard (Recommended)
Instead of manual setup, use the Torizon IDE Installation Wizard which automatically installs and configures the extension on Windows(2). This wizard handles all dependencies automatically and is the recommended approach.
3. Manual Xonsh Installation (If Continuing with Ubuntu 24.04)
If you must continue with Ubuntu 24.04 (unsupported), you can try manually installing xonsh:
sudo apt update
sudo apt install python3-pip
pip3 install xonsh
Then restart VS Code and try activating the extension again.
Important Notes
  • The Torizon IDE team does not support or test installations on Ubuntu 24.04(1)
  • Issues encountered on unsupported distributions may not have known solutions
  • For the best experience, use the Installation Wizard with the supported Ubuntu 22.04 distribution(2)
Next Steps
  1. Switch to Ubuntu 22.04 for official support
  2. Use the Installation Wizard for automated setup
  3. If issues persist on supported platforms, ensure VS Code is installed on Windows (not in WSL) and that you’re using Docker Engine (not Docker Desktop)(2)
@ToradexAI
xonsh IS installed. For some reason, it thinks it isn’t. Even the link is there.
This points to your password being set wrong or not entered. Could you confirm if the prompt to input the password is being shown?
@matheus.tx
Hi Matheus,
No, no request for PW. Also, the link is there despite what the log says. I did get another update of the VSC, maybe there is something going on there.
Also, for quite a while every time I load VSC and when it is running the extension, I get this message saying VSC needs to restart as “something” changed. If I reload it, it just repeats the case.
But now because of this not thinking xonsh is not installed, it doesn’t do the powershell connection. However, it seems to debug and work OK, despite all the hoopla.
Steve
Oh and when did 24.04 stop being supported? I went back through the links the AI mentioned above and couldn’t find any specific Ubuntu version listed at all. Maybe I just missed it…
It’s still supported, the AI is hallucinating.
This is weird, because it seems that it is asking for it and not receiving anything:
But ok, let’s try to debug this. Could you please run these commands and report back the output?
readlink -f ~/.local/bin/xonsh
readlink -f /usr/bin/xonsh
@matheus.tx
Hi Matheus,
/usr/bin/xonsh
I can debug and build just fine. BTW. Also, like I said, the powershell port connection page is not popping up anymore.
I am also getting this terminal error message:
The terminal process “/bin/bash ‘–norc’, ‘–noprofile’” terminated with exit code: 1.
And the normal log:
[05-06 08:11:56.797] Checkout templates repo to tag origin/bookworm-7 OK
[05-06 08:11:58.561] Error trying to setup xonsh
[05-06 08:11:58.700] ERROR :: Xonsh is not installed, Xonsh is required.
[05-06 08:11:58.700] WARNING :: Project name not found in workspace metadata for single container workspace, or it matches the workspace name.
[05-06 08:11:58.701] Checking connected devices …
[05-06 08:11:58.701] Scanning Torizon devices …
[05-06 08:11:58.709] Debian bookworm packages list load OK
[05-06 08:11:58.709] Configuring debug id_rsa …
[05-06 08:11:58.710] Debug id_rsa OK
[05-06 08:11:58.710] ERROR :: Errors during the initialization of Torizon IDE Extension.
[05-06 08:11:58.710] HOUSTON WE HAVE A PROBLEM!
[05-06 08:11:58.710] PLEASE READ THE LOGS!
[05-06 08:11:58.710] ERROR :: Please share this log on https://community.toradex.com
[05-06 08:11:58.936] Checking host ip sanity …
[05-06 08:12:04.225] Host ip is OK
Steve
Ok, so these should be the same, let’s workaround this by running:
sudo ln -sf /home/steve/.local/share/pipx/venvs/xonsh/bin/xonsh /usr/bin/xonsh
This should fix your `xonsh` installation error.
Let me know.
@matheus.tx
Yep, that did it. Except now I am getting the VSC restart:
I get this every time, even after the restart.
And why does everything work, except for the powershell stuff, which it did, the second time I launched VSC after the above change.
When i did the above change before: " ln -s" (missing -f), it said the link was already present.
Steve
As far I remember we do not ask for a restart for setting change anywhere on Torizon extension, so this should be from another extension, but share with me your `settings.json` so I could see what could be the reason.
@matheus.tx
“torizon_debug_ssh_port”: “2231”,
“torizon_debug_port1”: “2231”,
“torizon_debug_port2”: “”,
“torizon_debug_port3”: “”,
“torizon_login”: “torizon”,
“torizon_ip”: “10.40.100.5”,
“torizon_ssh_port”: “22”,
“host_ip”: “10.40.100.6”,
“torizon_workspace”: “${workspaceFolder}”,
“torizon_gpu”: “-imx8”,
“torizon_arch”: “arm64”,
“wait_sync”: “1”,
“torizon_run_as”: “torizon”,
“torizon_app_root”: “/home/torizon/app”,
“docker_tag”: “v0.0.0”,
“tcb.packageName”: “pName”,
“tcb.version”: “3.14.0”,
“torizon.gpuPrefixRC”: true,
“torizon.restartDocker”: false,
“terminal.integrated.defaultProfile.linux”: “bash”,
“git.ignoreLimitWarning”: true,
“torizon_psswd”: “xxxxxxx”,
“containers.environment”: {
“DOCKER_HOST”: “tcp://10.40.100.5:2375”
Yeah, from the local workspace settings, nothing calls my attention.
Could you please also share the global `settings.json`?
Press `F1` and select the option below:
This will show you the global `settings.json`
@matheus.tx
“makefile.configureOnOpen”: false,
“torizon.overwriteHostIp”: “x.x.x.5”,
“security.workspace.trust.startupPrompt”: “always”,
“security.restrictUNCAccess”: false,
“security.allowedUNCHosts”: [
“/home/me”,
“/home/me/”
“apollox.overwriteHostIp”: “x.x.x.6”,
“extensions.supportUntrustedWorkspaces”: {
“toradex.apollox-vscode”: {
“supported”: true,
“version”: “3.2.116”
"host_ip": "x.x.x.6",
"ipynb.experimental.serialization": false,
"ipynb.pasteImagesAsAttachments.enabled": false,
"apollox.experimental": false,
"apollox.debianRelease": "bookworm",
"security.workspace.trust.untrustedFiles": "open",
"security.promptForLocalFileProtocolHandling": false,
"security.promptForRemoteFileProtocolHandling": false,
"security.workspace.trust.banner": "always",
"redhat.telemetry.enabled": false,
"update.mode": "none",
"extensions.autoUpdate": false,
"apollox.templatesBranch": "bookworm-7",
"docker_login": "xxxxxx",
"docker_password": "xxxxxxx",
"torizon_arch": "aarch64",
"torizon_debug_port1": "2230",
"torizon_debug_ssh_port": "2230",
"torizon_login": "torizon",
"torizon_psswd": "xxxxxx",
"torizon_ip": "x.x.x.5",
"torizon_ssh_port": "22",
"torizon.templatesBranch": "bookworm-7",
"debug.disassemblyView.showSourceCode": false,
The message doesn’t show up until the last part of the extension happens, but before the powershell launches.
@EvetsMostel1
yeah, these security items appears to be suspicious. Let’s try something, remove from the global settings.json all torizon. or apollox. related. Leave these only on the global WSL settings.json. Let’s see if this make it behave a bit better. My theory is that when the extension set the device as default, and then write on the settings.json, it’s trying to update something on global that is triggering the restart.
@matheus.tx
OK. So, just so I am clear, in the VSC Preferences/settings, I remove torizon. and apollox. settings. Yes?
I tried doing this and ended up putting it all back because it doesn’t load the extension. Even after replacing it all back to what it was, it won’t load the extension. So, I made it check for updates, and still no joy. If I click on the torizon extension in the list, and try to add the device back, it says it doesn’t have that. Also there is no powershell action.
Steve
This is weird. Could you take a screenshot to show the VS Code window?
@matheus.tx
Sorry Matheus, this problem was due to my company changing their DNS servers and apparently, whatever is in the extension that attaches to a site, can’t resolve the IP address and so the Extension fails to launch, but I get no errors. What I have to do is under WSL, I have to use the 8.8.8.8 as a nameserver. Then the extension will launch.
So I removed all the apollox. and torizon. in the lower section. But I still get the message.
Then, I removed the rest of the ones in the first 2 sections. I don’t think it will work for me though because I need that “overwriteHostIp” one since I have two ethernet ports.
And now I can’t put the back the “apollox.overwriteHostIp” or the “torizon.overwriteHostIp”. I get an error when I try to startup VSC, saying the file isn’t valid.
Steve
@matheus.tx
I figured I would just go back to debugging, but now I am getting this timeout, which usually is associated with the DNS issue, which in this case, I have already made that adjustment.
failed to solve: DeadlineExceeded: torizon/debian:4: failed to resolve source metadata for docker.io/torizon/debian:4: failed to do request: Head “https://registry-1.docker.io/v2/torizon/debian/manifests/4”: dial tcp: lookup registry-1.docker.io: i/o timeout
When I go there with a browser, it’s complaining about Authorization:
{“errors”:[{“code”:“UNAUTHORIZED”,“message”:“authentication required”,“detail”:[{“Type”:“repository”,“Class”:“”,“Name”:“torizon/debian”,“Action”:“pull”}]}]}
