To access the boot menu on your Colibri iMX6 module, please ensure your serial connection is correctly configured. Here are some steps to help you troubleshoot and resolve the issue:
Verify Serial Connection:
- Ensure that the USB serial adapter is properly connected to the UART_A port on your Colibri evaluation board.
- Check the COM port number in Windows Device Manager to ensure you are connecting to the correct port in TeraTerm.
Configure Terminal Emulator:
- Set the terminal emulator (TeraTerm) to the correct baud rate, typically 115200 bps, with 8 data bits, no parity, 1 stop bit, and no flow control.
- Ensure that the terminal is set to display all incoming data.
Accessing the Boot Menu:
- Power on the device and immediately press any key in the terminal emulator to interrupt the boot process and access the U-Boot prompt.
- If the boot menu does not appear, verify that the serial cable and adapter are functioning correctly by testing with another device or cable.
Removing Boot Text from Splash Screen:
- To remove boot text, you will need to modify the U-Boot environment variables. This typically involves setting the
consolevariable tonullor removing it entirely to prevent output during boot. - Access the U-Boot prompt and use commands like
setenv console nullandsaveenvto apply changes.
I hope these steps help you access the boot menu and make the necessary changes. If you have any further questions, feel free to ask.
