Can’t connect to Toradex Easy Installer on iMX7 1GB with RDP (v2.0b6). I also can’t connect with VNC. Running on a Windows 10 PC.
I was able to connect with Tight VNC
Could you please provide more details about your setup?
Are you truing to use VMC over Ethernet or RNDIS?
Pleas use the latest version of Tight VNC or Real VNC.
Check your windows firewall settings.
I tried both, using Windows mstsc and VNCViewer.
TightVNC worked.
Thank you for the update!
