Hi there,
I want to try compile the zmq-php-bindings following the lead of this page: http://zeromq.org/bindings:php
But when I try to compile I got the following error:
root@colibri-imx7-emmc:~/php-zmq# phpize && ./configure
Configuring for:
PHP Api Version: 20160303
Zend Module Api No: 20160303
Zend Extension Api No: 320160303
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
checking for cc... cc
checking whether the C compiler works... no
configure: error: in `/home/root/php-zmq':
configure: error: C compiler cannot create executables
See `config.log' for more details
Here are the config.log:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ ./configure
## Platform. ##
hostname = colibri-imx7-emmc
uname -m = armv7l
uname -r = 4.9.84-2.8.3+gb2a7f2f
uname -s = Linux
uname -v = #1 SMP Sat Jun 9 16:15:05 UTC 2018
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/local/sbin
PATH: /usr/sbin
PATH: /sbin
## Core tests. ##
configure:2137: checking for grep that handles long lines and -e
configure:2195: result: /bin/grep
configure:2200: checking for egrep
configure:2262: result: /bin/grep -E
configure:2267: checking for a sed that does not truncate output
configure:2331: result: /bin/sed
configure:2470: checking for cc
configure:2486: found /usr/bin/cc
configure:2497: result: cc
configure:2528: checking for C compiler version
configure:2537: cc --version >&5
cc (GCC) 7.2.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2548: $? = 0
configure:2537: cc -v >&5
Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/arm-angstrom-linux-gnueabi/7.2.0/lto-wrapper
Target: arm-angstrom-linux-gnueabi
Configured with: ../../../../../../work-shared/gcc-7.2.0-r0/gcc-7.2.0/configure --build=x86_64-linux --host=arm-angstrom-linux-gnueabi --target=arm-angstrom-linux-gnueabi --prefix=/usr --exec_prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/libexec --datadir=/usr/share --sysconfdir=/etc --sharedstatedir=/com --localstatedir=/var --libdir=/usr/lib --includedir=/usr/include --oldincludedir=/usr/include --infodir=/usr/share/info --mandir=/usr/share/man --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/build/jenkins/v2017.12/compile/machine/colibri-vf/build/tmp-angstrom-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/gcc/7.2.0-r0/recipe-sysroot --with-gnu-ld --enable-shared --enable-languages=c,c++ --enable-threads=posix --enable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=arm-angstrom-linux-gnueabi- --without-local-prefix --enable-lto --enable-libssp --enable-libitm --disable-bootstrap --disable-libmudflap --with-system-zlib --with-linker-hash-style=gnu --enable-linker-build-id --with-ppl=no --with-cloog=no --enable-checking=release --enable-cheaders=c_global --without-isl --with-float=hard --with-sysroot=/ --with-build-sysroot=/build/jenkins/v2017.12/compile/machine/colibri-vf/build/tmp-angstrom-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/gcc/7.2.0-r0/recipe-sysroot --with-gxx-include-dir=/usr/include/c++/7.2.0 --without-long-double-128 --enable-nls --enable-initfini-array --with-arch=armv7-a
Thread model: posix
gcc version 7.2.0 (GCC)
configure:2537: cc -V >&5
cc: error: unrecognized command line option '-V'
cc: fatal error: no input files
compilation terminated.
configure:2548: $? = 1
configure:2537: cc -qversion >&5
cc: error: unrecognized command line option '-qversion'; did you mean '--version'?
configure:2568: checking whether the C compiler works
configure:2590: cc conftest.c >&5
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot open crtbegin.o: No such file or directory
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot open crtend.o: No such file or directory
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot find -lgcc
collect2: error: ld returned 1 exit status
configure:2594: $? = 1
configure:2632: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:2637: error: in `/home/root/php-zmq':
configure:2639: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_LT_SYS_LIBRARY_PATH_set=
ac_cv_env_LT_SYS_LIBRARY_PATH_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_GREP=/bin/grep
ac_cv_path_SED=/bin/sed
ac_cv_prog_ac_ct_CC=cc
## Output variables. ##
AR=''
AWK=''
CC='cc'
CFLAGS=''
CONFIGURE_COMMAND=' '\''./configure'\'' '
CONFIGURE_OPTIONS=''
CPP=''
CPPFLAGS=''
DEFS=''
DLLTOOL=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
FGREP=''
GREP='/bin/grep'
LD=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIPO=''
LN_S=''
LTLIBOBJS=''
LT_SYS_LIBRARY_PATH=''
MANIFEST_TOOL=''
NM=''
NMEDIT=''
OBJDUMP=''
OBJEXT=''
OTOOL64=''
OTOOL=''
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_URL=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PKG_CONFIG=''
RANLIB=''
RE2C=''
SED='/bin/sed'
SHELL='/bin/sh'
SHLIB_DL_SUFFIX_NAME=''
SHLIB_SUFFIX_NAME=''
STRIP=''
ac_ct_AR=''
ac_ct_CC='cc'
ac_ct_DUMPBIN=''
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE}'
dvidir='${docdir}'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target=''
target_alias=''
target_cpu=''
target_os=''
target_vendor=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 77
These are actually installed on my Colibri:
root@colibri-imx7-emmc:~# opkg list-installed | grep php
php - 7.1.9-r0.0
php-cgi - 7.1.9-r0.0
php-cli - 7.1.9-r0.0
php-dev - 7.1.9-r0.0
root@colibri-imx7-emmc:~# g++ -v
COLLECT_GCC=g++
Thread model: posix
root@colibri-imx7-emmc:~# gcc -v
COLLECT_GCC=gcc
Thread model: posix
root@colibri-imx7-emmc:~# ld -v
GNU gold (GNU Binutils 2.29.0.20170912) 1.14
I trying to fix this according some entries in stackoverflow and other forums, but nothing helps at the moment.
Got anyone a clue or a hint for me in which direction I have to look for solve this problem ?
Thanks in advance.
