Hi I am getting following error while adding device
Error running command apollox.NetworkDeviceAdd: command ‘apollox.NetworkDeviceAdd’ not found. This is likely caused by the extension that contributes apollox.NetworkDeviceAdd.
The error you’re encountering indicates that the VS Code extension cannot find the apollox.NetworkDeviceAdd command. This typically occurs when there’s an issue with the Torizon extension installation or configuration.
Ctrl+Shift+P to open the command paletteIf the issue persists after trying these solutions, the problem may be related to your specific VS Code configuration or system environment.
There was problem with latest Torizon extension. I reverted back to the stable version. For me 3.1.1 is running fine.
Dear @khaled.hassan,
Thank you for bringing this to our attention.
Would it be possible for you to share the initialisation logs, so we can further investigate this issue and check for a fix?
Collin
I have been in contact with our Torizon IDE team and they managed to deploy a fix on the latest IDE version V3.2.2. Here are the change logs:
Changelog v3.2.2 (VS Code IDE)
Collin
