Hi all,
I recently used the Torizon Easy installer to install a newer version of the Torizon Easy Installer on my Colibri IMX8DX V1.0B Module which is mounted on an Aster Carrier Board. Unfortunately since the installation has been completed, the board stopped reacting completely. There is not output on the connected screen neither is there anything when connection it via UART to a serial console.
I try to use recovery mode to flash the Easy Installer again. However it seems that I can’t even reach recovery mode.
I try to reach it the following way:
1.) Connect USB-Cables to both Micro-USB Ports, shorten the pins as described here (NXP i.MX and TI AM62x Recovery Mode | Toradex Developer Center) and turn the board on keeping the pins shorted for >6 sec. I also tried the same with disconnecting everything and reconnecting again as suggested in the warning.
After that I run the recovery-linux.sh from the downloaded Torizon Easy Installer package. The script is stuck at "Wait for Known USB Device Appear… ". To me that sounds like on a successful entry into recovery mode, the board should be recognized as USB device. However, the only thing that appears is the UART connection
(Future Technology Devices International, Ltd FT232 USB-Serial (UART)).
Is there something I’m doing wrong in my approach? How would I see that I correctly entered recovery mode?
Best regards!
