Cannot update rootfs from UBoot
I am trying to build and flash my embedded system. But I don’t seem to be able to update the rootfs to the flash, as described in the UBoot documentation. This is the procedure I used:
I unpacked the 2.6 distribution UBoot and attempted to flash to my IMX6 board:
Colibri iMX6 # run update_uboot
Using FEC device
TFTP from server 192.168.10.1; our IP address is 192.168.10.2
Filename ‘colibri_imx6/u-boot.imx’.
Load address: 0x12000000
Loading: ################################################## 307 KiB
8.3 MiB/s
done
Bytes transferred = 314368 (4cc00 hex)
switch to partitions #1, OK
mmc0(part 1) is current device
MMC write: dev # 0, block # 2, count 614 … 614 blocks written: OK
done.
Fuse 0, 5: 5072
Fast boot mode already fused, no need to fuse
Colibri iMX6 #
I then power-cycled the board
U-Boot 2015.04+fslc+ge1a48b2 (Mar 31 2016 - 01:22:38)
CPU: Freescale i.MX6DL rev1.3 at 792 MHz
CPU: Temperature 55 C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
force_idle_bus: sda=0 scl=1 sda.gp=0x6 scl.gp=0x3
force_idle_bus: failed to clear bus, sda=0 scl=1
PMIC: device id: 0x10, revision id: 0x21
PMIC: programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX6 DualLite 512MB V1.0B, Serial# 04944308
Net: using PHY at 0
FEC [PRIME]
Normal Boot
Colibri iMX6 # version
arm-angstrom-linux-gnueabi-gcc (Linaro GCC 5.2-2015.11-2) 5.2.1 20151005
GNU ld (GNU Binutils) Linaro 2015.01-2 2.25.0
I then ran setupdate
Colibri iMX6 # run setupdate
MMC: no card present
** Bad device mmc 1 **
starting USB…
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
scanning usb for ethernet devices… 0 Ethernet Device(s) found
** Bad device usb 0 **
Using FEC device
Filename ‘flash_eth.img’.
Load address: 0x10800000
Loading: ################################################## 444 Bytes
61.5 KiB/s
done
Bytes transferred = 444 (1bc hex)
Executing script at 10800000
Using FEC device
Filename ‘colibri_imx6/flash_eth.img’.
Loading: ################################################## 3.6 KiB
518.6 KiB/s
done
Bytes transferred = 3720 (e88 hex)
Executing script at 12000000
enter “run update” to update the entire module
Then printenv: no update-rootfs present!!!
Colibri iMX6 # printenv
arch=arm
baudrate=115200
board=colibri_imx6
board_name=colibri_imx6
board_rev=010b
boot_file=uImage
bootcmd=run emmcboot ; echo ; echo emmcboot failed ; run nfsboot ; echo ; echo nfsboot failed ; usb start ;setenv stdout serial,vga ; setenv stdin serial,usbkbd
bootdelay=1
check_1=setenv conf_blk_offset 0x1fff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_2=setenv conf_blk_offset 0xfff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_3=setenv conf_blk_offset 0x7ff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_configblock=setexpr toradex_oui_addr ${loadaddr} + 8; mw.l ${kernel_addr_r} 0x002d1400; mmc dev 0 1; run check_1 || run check_2 || run check_3; cmp.b ${kernel_addr_r} ${toradex_oui_addr} 3
console=ttymxc0
cp_file_chunk=tftpboot ${loadaddr} ${board_name}/root.ext3-${filenum}; run set_blkcnt; mmc dev 0 0 && mmc write ${loadaddr} ${blkstart} ${blkcnt}
cpu=armv7
defargs=enable_wait_mode=off galcore.contiguousSize=50331648
dfu_alt_info=u-boot.imx raw 0x2 0x3ff mmcpart 0;boot part 0 1;rootfs part 0 2;uImage fat 0 1;imx6q-colibri-eval-v3.dtb fat 0 1;imx6q-colibri-cam-eval-v3.dtb fat 0 1
drive=0
echo_migrate=echo successfully updated U-Boot, power-cycle and enter \“run setupdate\; run migrate\” to complete update
emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait
emmcboot=run setup; setenv bootargs ${defargs} ${emmcargs} ${setupargs} ${vidargs}; echo Booting from internal eMMC chip…; run emmcdtbload; load mmc 0:1 ${kernel_addr_r} ${boot_file} && bootm ${kernel_addr_r} ${dtbparam}
emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
ethact=FEC
ethaddr=00:14:2d:4b:71:b4
ethprime=FEC
fdt_addr_r=0x12000000
fdt_file=imx6dl-colibri-eval-v3.dtb
fileaddr=12000000
filesize=e88
incr_decimal=setexpr filenum ${filenum} + 1; setexpr filenrlow ${filenum} % 0x10; test ${filenrlow} -eq “a” && setexpr filenum ${filenum} + 0x6; true
interface=usb
ipaddr=192.168.10.2
kernel_addr_r=0x10800000
loadaddr=0x12000000
migrate=run migrate_configblock; run update_latest; reset
migrate_configblock=run check_configblock; mmc dev 0 0 && mmc read ${loadaddr} 0x500 1 && cmp.b ${kernel_addr_r} ${toradex_oui_addr} 3 && mmc dev 0 1 && mmc write ${loadaddr} ${conf_blk_offset} 1
migrate_uboot=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 1 && mmc write ${loadaddr} 2 ${blkcnt} && patch_ddr_size && mmc bootbus 0 2 1 2 && mmc partconf 0 1 1 0
migrate_uboot_old=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 0 && mmc write ${loadaddr} 2 ${blkcnt}; patch_ddr_size
netmask=255.255.255.0
nfsargs=ip=:::::eth0:on root=/dev/nfs rw netdevwait
nfsboot=run setup; setenv bootargs ${defargs} ${nfsargs} ${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS…; run nfsdtbload; dhcp ${kernel_addr_r} && bootm ${kernel_addr_r} ${dtbparam}
nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
ramdisk_addr_r=0x12100000
sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext3 rootwait
sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} ${vidargs}; echo Booting from SD card; run sddtbload; load mmc 1:1 ${kernel_addr_r} ${boot_file} && bootm ${kernel_addr_r} ${dtbparam}
sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
serial#=04944308
serverip=192.168.10.1
set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
set_nextnum=run incr_decimal; setexpr blkstart ${blkstart} + ${blkcnt}
setethupdate=if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; tftpboot ${kernel_addr_r} flash_eth.img
setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; load ${interface} ${drive}:1 ${kernel_addr_r} flash_blk.img
setup=setenv setupargs fec_mac=${ethaddr} consoleblank=0 no_console_suspend=1 console=tty1 console=${console},${baudrate}n8
setupdate=run setsdupdate || run setusbupdate || run setethupdate; source ${kernel_addr_r}
setusbupdate=usb start && setenv interface usb; setenv drive 0; load ${interface} ${drive}:1 ${kernel_addr_r} flash_blk.img
soc=mx6
splashpos=m,m
update=mmc bootbus 0 2 0 1 && run update_new && exit; run update_v2.4b1
update_1=tftpboot ${loadaddr} ${board_name}/mbr.bin && mmc dev 0 0 && mmc write ${loadaddr} 0x0 0x1
update_2=tftpboot ${loadaddr} ${board_name}/boot.vfat && run set_blkcnt && mmc dev 0 0 && mmc write ${loadaddr} 0x2000 ${blkcnt}
update_3=setenv filesize 4000000; setenv filenum 10; setenv blkstart a000; while test ${filesize} -eq “4000000”; do run cp_file_chunk; run set_nextnum; done; true
update_configblock=run check_configblock; tftpboot ${loadaddr} ${board_name}/configblock.bin && mmc dev 0 1 && mmc write ${loadaddr} ${conf_blk_offset} 1
update_fdt=tftpboot ${loadaddr} ${board_name}/${fdt_file} && fatwrite mmc 0:1 ${loadaddr} ${fdt_file} ${filesize}
update_kernel=tftpboot ${loadaddr} ${board_name}/uImage && fatwrite mmc 0:1 ${loadaddr} uImage ${filesize}
update_latest=run update_uboot; run update_1; run update_2; run update_kernel; run update_fdt; run update_3
update_new=updt_fuse -n && run update_latest && reset; run update_v2.5b3
update_uboot=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 1 && mmc write ${loadaddr} 2 ${blkcnt} && patch_ddr_size && updt_fuse && mmc bootbus 0 2 0 1 && mmc partconf 0 1 1 0 && mmc rst-function 0 1
update_v2.4b1=run check_configblock || run migrate_configblock; run migrate_uboot_old && run echo_migrate
update_v2.5b3=run check_configblock || run migrate_configblock; run migrate_uboot && run echo_migrate
vendor=toradex
ver=U-Boot 2015.04+fslc+ge1a48b2 (Mar 31 2016 - 01:22:38)
vidargs=video=mxcfb0:dev=lcd,640x480M@60,if=RGB666 video=mxcfb1:off fbmem=8M
Environment size: 5952/8188 bytes
Colibri iMX6 #
To update the rootfs alone one can use ‘# run update_3’.
NOTE:
TFTP update requires manual splitting of the root.ext3 file which can be taken care of by the -c argument with update.sh script.
