I am trying to set the value of GPIO1.14 (SODIMM 99) from userspace, on my custom carrier board. According to this mapping, it is pin number 14. I’ve used these commands:
echo 14 > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio14/direction
echo 0 > /sys/class/gpio/gpio14/value
echo 1 > /sys/class/gpio/gpio14/value
The problem is that the pin is always high.
I’ve also tried with gpioset. I confirm that the pin’s state changes correctly in the output of cat /sys/kernel/debug/gpio. E.g., the output after echo 0:
cat /sys/kernel/debug/gpio | grep 99
gpio-14 (SODIMM_99 |sysfs ) out lo
I also confirm that there is no hardware problem (the pin is connected to a pulldown resistor and I have verified the connectivity from the SODIMM 99 pad to resistor’s pad).
I did not encounter this problem with other pins. My device tree is based on the Iris v2 device tree and I have attached my diff file.
Does anybody know what is the problem?
