“Cannot connect to PC. Stop any programs that may be using a connection, and try again. If the problem persists, reset your device according to the owner’s manual”.
Hi. Sorry for the delay. I already looked into this but did not yet find solution. It will take me some time to try and fix it. I will get back to you in 10 days.
Our app should be able to prevent system from going to sleep, because app interacts with peripheral modules such as gprs modem, bluetooth. When Colibri turn into sleep mode, battery driver power off this modules. Instead of just go to suspend, Colibri goes to sleep by means of PM, and if we don’t want sleep, we using SystemIdleTimerReset () in app. PM doesn’t Colibri into sleep mode until Active Sync is turned off when USB connected.
