Cannot connect to Apalis iMX8 Ixora board over serial connection with VSCode Torizon extension
Hi @SJ_BHD !
Did you manage to use VS Code to deploy your application to the module using the network?
Let us know if your issue was solved.
We are using the network, but using a serial method or perhaps a method where we have the container on a usb , connect to the dahlia usb board and do it that way.
Hi @SJ_BHD !
To copy the docker image somewhere, you can refer to @jeremias.tx’s last answer regarding docker save/load:
Hello @SJ_BHD ,
Were you able to try the solution proposed by @henrique.tx ?
Josep
