Hi all,
here I have uploaded a example project to send and receive can frames.
The application uses the CE libraries v2.2.
There is a RX task with priority 42 and a TX task with priority 40.
The CAN task from the CanLib is at priority 12.
There is also a producer/consumer task with priotity 64.
This task wants to send CAN messages in a 100ms interval.
If I run the program and trace the frames, the messages are send in a 1000ms interval.
This is the time I specified with the Can_SetConfigInt(hCan, L"Timeout", wTimeout, StoreVolatile); function.
If I change wTimeout to 500ms, the messages are send in a 500ms interval and so on.
I think the RX task is blocking until the timeout expires and the producer task can’t interrupt the RX task.
In the release notes for CE lib 2.2 i readed “Improved CAN Library”.
Has this something to do with my problem?
Because with CE libs v2.0 the program worked.
Or what can I do to solve the problem?
I also tried to set wTimeout to 1ms. The performance for my application was ok, but I don’t think that this is good for the whole system if every millisecond the RX task is active.
Thanks for any advice.
Kind regards,
kuzco
