Dear Community,
I’m working with the Colibri iMX8X and an Aster Carrier Board to set the CAN. Since the documentation for this module isn’t ready, I’m using the available documentation here and here as a guide, but there are still some differences.
I opened the files fsl-imx8qxp-colibri-aster.dts and fsl-imx8qxp-colibri.dtsi from the linux-toradex git (Version: toradex_4.14-2.0.x-imx) and this the following changes:
ec@ec:~$ diff -u ~/fsl-imx8qxp-colibri-aster_original.dts ~/linux-toradex/arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dts
--- /home/ec/fsl-imx8qxp-colibri-aster_original.dts 2020-03-10 12:02:04.795095000 +0100
+++ /home/ec/linux-toradex/arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dts 2020-03-11 08:45:32.634844761 +0100
@@ -102,6 +102,10 @@
+&can1 {
+ status = "okay";
/* Colibri SPI */
&lpspi2 {
ec@ec:~$ diff -u ~/fsl-imx8qxp-colibri_original.dtsi ~/linux-toradex/arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri.dtsi
--- /home/ec/fsl-imx8qxp-colibri_original.dtsi 2020-03-11 09:01:33.803521600 +0100
+++ /home/ec/linux-toradex/arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri.dtsi 2020-03-11 08:34:42.255913018 +0100
@@ -525,8 +525,8 @@
/* Colibri optional CAN on PS2 */
pinctrl_flexcan2: flexcan1grp {
fsl,pins = <
- SC_P_FLEXCAN1_TX_ADMA_FLEXCAN1_TX 0x21 /* SODIMM 55 */
- SC_P_FLEXCAN1_RX_ADMA_FLEXCAN1_RX 0x21 /* SODIMM 63 */
+ SC_P_FLEXCAN1_TX_ADMA_FLEXCAN1_TX 0x06000021 /* SODIMM 55 */
+ SC_P_FLEXCAN1_RX_ADMA_FLEXCAN1_RX 0x06000021 /* SODIMM 63 */
At this point when I run the command make dtbs
I get the following mistake:
ec@ec:~/linux-toradex$ make dtbs
CHK include/config/kernel.release
UPD include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
UPD include/generated/utsrelease.h
CHK include/generated/bounds.h
CHK include/generated/timeconst.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK scripts/mod/devicetable-offsets.h
DTC arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dtb
Error: arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dts:105.1-6 Label or path can1 not found
FATAL ERROR: Syntax error parsing input tree
scripts/Makefile.lib:317: recipe for target 'arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dtb' failed
make[2]: *** [arch/arm64/boot/dts/freescale/fsl-imx8qxp-colibri-aster.dtb] Error 1
scripts/Makefile.build:585: recipe for target 'arch/arm64/boot/dts/freescale' failed
make[1]: *** [arch/arm64/boot/dts/freescale] Error 2
arch/arm64/Makefile:138: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
Thanks for the help. Kind regards.
